I'm trying to get tts working on Kodi 18.5 (installed on a nuc with LibreELEC) I have all the options in the user manual selected, all the options on the kodi machine but for some reason I can't get tts working. When I type in "Kodi:theater" it does nothing, when I select no speakers and just have it broadcast to everything it just sends kodi a notification instead of speaking it. (i've tried setting 'foward speak actions' to yes and no, i've also tried setting the "send speak actions as notifications" to yes or no and still tts doesn't seem to work.
TTS with LibreELEC 18.5
Have you tried casting to KODI? I don't know if am wright but check along those lines. This here : https://cormang.com/2018/06/30/how-to-stream-or-cast-from-windows-to-kodi/ is a generalized way of what should be enabled.
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
Originally posted by spud View PostThe Kodi plugin doesn't do any TTS, it just uses the "Speak Proxy" feature of HS to send text notifications.
if you want to do TTS through Kodi, you can try to enable Airplay in Kodi and use the AirplaySpeak plugin.
Originally posted by Eman View PostHave you tried casting to KODI? I don't know if am wright but check along those lines. This here : https://cormang.com/2018/06/30/how-to-stream-or-cast-from-windows-to-kodi/ is a generalized way of what should be enabled.
Eman.
Originally posted by Hsuser View Post
Haven't thought about that, i'll have to try it out. Question is since i've tried using airplay in the past for other things, does it 'stay' connected after it finishes speaking or does it disconnect so whatever else was playing at the time of the tts can resume playing?
