Kodi 18.9, and PlugIn 3.0.1.14 (both of which I believe are the latest versions) - other than moving to Matrix of course.
We have a Kodi player that's only in use some of the time - mainly when my wife is doing her crafting. When she's done, she turns of the monitor, Kodi, and her crafting machinery.
When she does turn it off, the PlugIn is obviously unable to communicate with it, and I'm getting a load of errors in the logs as the PlugIn tries to reconnect.
Is there any way to tell the PlugIn not to try and reconnect with this Kodi player, and then to tell it to reconnect later when the room is occupied? If there's something in the PlugIn I can use, I can add it to the lights on automation event for the room.
Thanks.
G
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
Thanks.
G
