Since upgrading my kodi boxes to Matrix V19 I am having issues running the kodi action in HS , Execute Addon. I select the Addon ID, only when trying pass parameters as documented in that kodi addon, I get an error in the HS log that suggests the format of the additional parameters is not in the format expected by the addon. Suggestions? This is in conjunction with a new version of the security cam overlay which does not need separate installs of the zip files, but can support up to 4 cameras natively by calling the index id of the camera.
Addon parameters
Originally posted by spud View PostSorry for the delay
What is the addon id? What is the parameter you are trying to pass? and what is the exact error you get in the log?
Does the exact same event action worked with the previous version of Kodi (Leia) with the same addon?
According to the log .
DEBUG <--192.168.128.88:8080 { "error": { "code": -32602, "message": "Invalid params." }, "id": 4, "jsonrpc": "2.0" }
6/17/2021 3:45:27 PM
Legacy-Plugin
Kodi
DEBUG -->192.168.128.88:8080 { "jsonrpc": "2.0", "method": "Addons.ExecuteAddon", "params": { "addonid": "script.securitycam,streamid=1", "wait": false }, "id": 4 }
I have also tried separating the parameters into the json format parameters in the plugin but that does not seem to work either.
