Kodi/XBMC Plug-in - Beta Testing
This is a sticky topic.
  • Done it, now getting more result, but still have an error about wrong port, my port is 8189. And it show in the log:
    Queuing plugin Kodi to load...
    03:32:45:9917:[Plug-In]->Finished initializing plug-in Kodi
    Plugin: Kodi Instance:  starting...
    Connecting to server at 127.0.0.1...
    Connection attempt #1
    03:32:46:1566:[Info]->Plugin Kodi has connected. IP:127.0.0.1:46166
    Connected (HomeSeer API 3). Waiting to be initialized...
    03:32:46:2132:[Starting Plug-In]->Initializing plugin Kodi ...
    May-27 15:32:46 INFO Kodi version 3.0.1.11
    03:32:46:2186:[Kodi]->INFO Kodi version 3.0.1.11
    03:32:46:3658:[Starting Plug-In]->Plugin Kodi started successfully in 152 milliseconds
    May-27 15:32:46 INFO Found Service: Kodi (Consciousness)
    03:32:46:4870:[Kodi]->INFO Found Service: Kodi (Consciousness)
    03:32:46:4872:[Kodi]->INFO Found Service: Kodi (Consciousness)
    May-27 15:32:46 INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc._tcp - 192.168.100.55 - 9090
    03:32:46:4960:[Kodi]->INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc._tcp - 192.168.100.55 - 9090
    May-27 15:32:46 INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc-h._tcp - fe80::208:9bff:fef6:b5a5 - 8189
    03:32:46:4969:[Kodi]->INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc-h._tcp - fe80::208:9bff:fef6:b5a5 - 8189
    May-27 15:32:46 ERROR Invalid URI: Invalid port specified.
    03:32:46:5252:[Kodi]->ERROR Invalid URI: Invalid port specified.
    03:32:53:3329:[Updater]->An item in the Updater is temporarily unavailable: Error getting response stream (ReadDoneAsync2): ReceiveFailure Item: http://www.highpeak.co.za/updates3/SMS-Gateway_UPDATER.txt
    I did put manually configuration into the Kodi file:
    [PLAYERS]
    1###name=TV Room
    1###ipaddress=192.168.100.55
    1###port=8189
    1###username=myusername
    1###password=mypassword
    • Originally posted by 838Joel View Post
      [PLAYERS]
      1###name=TV Room
      1###port=8189
      From the config page set the log level to Debug.
      Avahi now discover correctly your Kodi player, so remove what you put in the ini file this should not be needed, then restart the plug-in.
      • BUT, I got some improvement, still an error about the port when I try to connect, but at least I can click now on the Kodi link and see my configuration/connection parameters...
        Is it related to the tcp port 9090?
        • Okay great, all good now!
          Connected, did not play much yet, but look to be on the good path
          But I still have this staus: INFO: Plugin start is pending
          Is that normal?
          Kodi and PushOver are giving me this status all the time!
            Is that normal?
            Do you still have this status, if you reload the page?
            • Yes still there!
              Sent from my Nexus 6P using Tapatalk
              • Ok, i restarted my VM and now all status are OK.
                I still have some errors, any clue how to fix those errors about ALSA lib?
                > 04:21:46:4704:[TTS]->Speak ():Welcome to Home-Seer
                ALSA lib confmisc.c:767:(parse_card) cannot find card '0'
                ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
                ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
                ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
                ALSA lib confmisc.c:1246:(snd_func_refer) error evaluating name
                ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
                ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
                ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM default
                aplay: main:788: audio open error: No such file or directory
                May-27 16:21:46 INFO Found Service: Kodi (Consciousness)
                04:21:46:5817:[Kodi]->INFO Found Service: Kodi (Consciousness)
                04:21:46:5820:[Kodi]->INFO Found Service: Kodi (Consciousness)
                May-27 16:21:46 INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc-h._tcp - 192.168.100.55 - 8189
                May-27 16:21:46 INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc._tcp - 192.168.100.55 - 9090
                04:21:46:5899:[Kodi]->INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc-h._tcp - 192.168.100.55 - 8189
                04:21:46:5903:[Kodi]->INFO Resolved Service: Kodi (Consciousness) - _xbmc-jsonrpc._tcp - 192.168.100.55 - 9090
                04:21:46:6039:[Info]->System connected to MyHS Service, waiting for acknowledge...
                May-27 16:21:46 DEBUG Connecting to 192.168.100.55 on tcp port 9090
                04:21:46:6265:[Kodi]->DEBUG Connecting to 192.168.100.55 on tcp port 9090
                04:21:46:6359:[Info]->System connected to MyHS Service successfully with license ID .
                May-27 16:21:46 DEBUG Pinging 192.168.100.55 on http port 8189
                04:21:46:6368:[Kodi]->DEBUG Pinging 192.168.100.55 on http port 8189
                May-27 16:21:46 DEBUG -->192.168.100.55:8189
                Maybe not related to your plugin, but if you have a clue that can help!
                And thank for all your help, can't wait to discover how to use the newly purchase plugin and integrate that in my new learning of Homeseer!
                I'm sure I'll get more fun then with my old Vera
                Joel
