**FATAL**: Failed getting InterfaceStatus from XBMC - the interface was not found in
  • **FATAL**: Failed getting InterfaceStatus from XBMC - the interface was not found in
    I get this error when i try installing it.
    **FATAL**: Failed getting InterfaceStatus from XBMC - the interface was not found in the list of active interfaces.
    What does that mean? I tried uninstalling it, restarting HS3 etc. Nothing...
    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
    is there more info in the logs?
    please post what you have in the logs (VIEW > LOG) when you try to install the plugin and start it
      jan-10 12:32:20 Plug-In Finished initializing plug-in XBMC
      jan-10 12:32:17 Info Plugin XBMC with instance: has disconnected
      jan-10 12:32:17 Error Initializing plug-in(1): XBMC Instance::System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders() at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider( ) at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () at Mono.Zeroconf.ServiceBrowser..ctor() at HSPI_XBMC.XBMCPlayerDiscoverer.Start() at HSPI_XBMC.XBMCApp.Init()
      jan-10 12:32:17 XBMC ERROR System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders() at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider( ) at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () at Mono.Zeroconf.ServiceBrowser..ctor() at HSPI_XBMC.XBMCPlayerDiscoverer.Start() at HSPI_XBMC.XBMCApp.Init()
      jan-10 12:32:17 XBMC INFO XBMC version 3.0.0.28
      jan-10 12:32:17 Info Plugin XBMC has connected. IP:127.0.0.1:57520
      jan-10 12:32:17 Plug-In Interface XBMC is running as a trial, 30 days remaining.
        you need to install Bonjour as explained in the User Guide: http://board.homeseer.com/showthread.php?t=161821
          Ah i need it on the server aswell. I do have it on the HTPC. Now it seems like i manage to get it running. Thank you!
            Hey guys, I just wanted to say thanks for posting this thread here because I had the same problem.
            I think the documentation should be a little bit more clear, that bonjour is required on the system that is running HS3, and NOT just on the system that is running Kodi.
            In my case, I have multiple instances of kodi around the house and it wasn't until I installed bonjour onto the HS3 computer that this plugin worked.
            Hope this helps clarify for other people
              I just made some changes to the User Guide to try to make that more clear.
              Thanks for the feedback.
                I am getting a Warning: instead of Fatal, but similar wording. It sometimes gives me this and then I leave it alone and it fixes itself some how but now it seems to be stuck. I have tried disabling/re-enabling and restarting HS3 with no luck. Below is the most recent log when I enabled plugin.
                Mar-29 9:07:16 PM	 	Info	Plugin XBMC with instance: has disconnected
                Mar-29 9:07:16 PM	 	XBMC	ERROR Error 2012, cannot continue
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: Guest - _xbmc-jsonrpc-h._tcp. - 192.168.1.104 - 8080
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: Guest - _xbmc-jsonrpc._tcp. - 192.168.1.104 - 9090
                Mar-29 9:07:09 PM	 	XBMC	INFO Found Service: Guest
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: MediaRoom - _xbmc-jsonrpc._tcp. - 192.168.1.101 - 9090
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: MediaRoom - _xbmc-jsonrpc-h._tcp. - 192.168.1.101 - 8080
                Mar-29 9:07:09 PM	 	XBMC	INFO Found Service: MediaRoom
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: Game3 - _xbmc-jsonrpc-h._tcp. - 192.168.1.108 - 8080
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: Game3 - _xbmc-jsonrpc._tcp. - 192.168.1.108 - 9090
                Mar-29 9:07:09 PM	 	XBMC	INFO Found Service: Game3
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: BillyOffice - _xbmc-jsonrpc-h._tcp. - 192.168.1.102 - 8080
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: BillyOffice - _xbmc-jsonrpc._tcp. - 192.168.1.102 - 9090
                Mar-29 9:07:09 PM	 	XBMC	INFO Found Service: BillyOffice
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: Game2 - _xbmc-jsonrpc._tcp. - 192.168.1.103 - 9090
                Mar-29 9:07:09 PM	 	XBMC	INFO Resolved Service: Game2 - _xbmc-jsonrpc-h._tcp. - 192.168.1.103 - 8080
                Mar-29 9:07:08 PM	 	XBMC	INFO Found Service: Game2
                Mar-29 9:07:08 PM	 	XBMC	INFO Resolved Service: Game1 - _xbmc-jsonrpc-h._tcp. - 192.168.1.107 - 8080
                Mar-29 9:07:08 PM	 	XBMC	INFO Found Service: Game1
                Mar-29 9:07:08 PM	 	XBMC	INFO Resolved Service: Game1 - _xbmc-jsonrpc._tcp. - 192.168.1.107 - 9090
                Mar-29 9:07:08 PM	 	XBMC	INFO Resolved Service: MasterBed - _xbmc-jsonrpc-h._tcp. - 192.168.1.100 - 8080
                Mar-29 9:07:08 PM	 	XBMC	INFO Found Service: MasterBed
                Mar-29 9:07:08 PM	 	XBMC	INFO Resolved Service: MasterBed - _xbmc-jsonrpc._tcp. - 192.168.1.100 - 9090
                Mar-29 9:07:07 PM	 	XBMC	INFO Resolved Service: Family - _xbmc-jsonrpc-h._tcp. - 192.168.1.106 - 8080
                Mar-29 9:07:07 PM	 	XBMC	INFO Found Service: MasterBed
                Mar-29 9:07:07 PM	 	XBMC	INFO Resolved Service: Family - _xbmc-jsonrpc._tcp. - 192.168.1.106 - 9090
                Mar-29 9:07:07 PM	 	XBMC	INFO Found Service: Family
                Mar-29 9:04:41 PM	 	Error	Initializing plug-in(2): XBMC Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
                Mar-29 9:03:41 PM	 	XBMC	ERROR Error 2012, cannot continue
                Mar-29 9:03:36 PM	 	XBMC	INFO Resolved Service: Guest - _xbmc-jsonrpc-h._tcp. - 192.168.1.104 - 8080
                Mar-29 9:03:36 PM	 	XBMC	INFO Found Service: Guest
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: Guest - _xbmc-jsonrpc._tcp. - 192.168.1.104 - 9090
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: MediaRoom - _xbmc-jsonrpc-h._tcp. - 192.168.1.101 - 8080
                Mar-29 9:03:35 PM	 	XBMC	INFO Found Service: MediaRoom
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: Game3 - _xbmc-jsonrpc-h._tcp. - 192.168.1.108 - 8080
                Mar-29 9:03:35 PM	 	XBMC	INFO Found Service: Guest
                Mar-29 9:03:35 PM	 	XBMC	INFO Found Service: Game3
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: MediaRoom - _xbmc-jsonrpc._tcp. - 192.168.1.101 - 9090
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: BillyOffice - _xbmc-jsonrpc-h._tcp. - 192.168.1.102 - 8080
                Mar-29 9:03:35 PM	 	XBMC	INFO Found Service: BillyOffice
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: Game2 - _xbmc-jsonrpc-h._tcp. - 192.168.1.103 - 8080
                Mar-29 9:03:35 PM	 	XBMC	INFO Resolved Service: Game3 - _xbmc-jsonrpc._tcp. - 192.168.1.108 - 9090
                Mar-29 9:03:34 PM	 	XBMC	INFO Found Service: Game3
                Mar-29 9:03:34 PM	 	XBMC	INFO Found Service: Game2
                Mar-29 9:03:34 PM	 	XBMC	INFO Resolved Service: BillyOffice - _xbmc-jsonrpc._tcp. - 192.168.1.102 - 9090
                Mar-29 9:03:34 PM	 	XBMC	INFO Found Service: BillyOffice
                Mar-29 9:03:34 PM	 	XBMC	INFO Resolved Service: Game1 - _xbmc-jsonrpc-h._tcp. - 192.168.1.107 - 8080
                Mar-29 9:03:34 PM	 	XBMC	INFO Resolved Service: Game2 - _xbmc-jsonrpc._tcp. - 192.168.1.103 - 9090
                Mar-29 9:03:33 PM	 	XBMC	INFO Found Service: Game1
                Mar-29 9:03:33 PM	 	XBMC	INFO Resolved Service: Game1 - _xbmc-jsonrpc._tcp. - 192.168.1.107 - 9090
                Mar-29 9:03:33 PM	 	XBMC	INFO Resolved Service: MasterBed - _xbmc-jsonrpc-h._tcp. - 192.168.1.100 - 8080
                Mar-29 9:03:33 PM	 	XBMC	INFO Found Service: MasterBed
                Mar-29 9:03:33 PM	 	XBMC	INFO Resolved Service: MasterBed - _xbmc-jsonrpc._tcp. - 192.168.1.100 - 9090
                Mar-29 9:03:33 PM	 	XBMC	INFO Resolved Service: Family - _xbmc-jsonrpc-h._tcp. - 192.168.1.106 - 8080
                Mar-29 9:03:33 PM	 	XBMC	INFO Resolved Service: Family - _xbmc-jsonrpc._tcp. - 192.168.1.106 - 9090
                Mar-29 9:03:32 PM	 	XBMC	INFO Found Service: Family
                Mar-29 9:03:11 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer7. Plugin: XBMC Instance:
                Mar-29 9:02:55 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer6. Plugin: XBMC Instance:
                Mar-29 9:02:41 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer5. Plugin: XBMC Instance:
                Mar-29 9:02:40 PM	 	Plug-In	Finished initializing plug-in XBMC
                Mar-29 9:02:30 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer4. Plugin: XBMC Instance:
                Mar-29 9:02:18 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer3. Plugin: XBMC Instance:
                Mar-29 9:02:06 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer2. Plugin: XBMC Instance:
                Mar-29 9:01:54 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcplayer1. Plugin: XBMC Instance:
                Mar-29 9:01:41 PM	 	Warning	Attempt by plugin to register a duplicate link of http://board.homeseer.com/forumdisplay.php?f=1149. Plugin: XBMC Instance:
                Mar-29 9:01:41 PM	 	Warning	Attempt by plugin to register a duplicate link of http://board.homeseer.com/showthread.php?t=161821. Plugin: XBMC Instance:
                Mar-29 9:01:41 PM	 	Warning	Attempt by plugin to register a duplicate link of xbmcconfig. Plugin: XBMC Instance:
                Mar-29 9:01:41 PM	 	XBMC	INFO XBMC version 3.0.0.37
                Mar-29 9:01:41 PM	 	Info	Plugin XBMC has connected. IP:127.0.0.1:60023
                Mar-29 9:01:25 PM	 	Error	Initializing plug-in(2): XBMC Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.PropagateIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
