Kodi and Advanced Launcher
  • Kodi and Advanced Launcher
    I am trying to Execute a Kodi Addon "Advanced Launcher"
    It does support JSON control however i can't seem to get it to load properly
    Here is the post from the developer that details this.
    http://forum.kodi.tv/showthread.php?...066#pid1501066
    I have created an event and can use the Execute Addon feature however when i try to use your example (with the security cam addon) for passing parameters, it never loads
    I went the XML file and pulled the category and id that the previous post said is requred.
    <launcher>
      <id>23a0c4d3a0b4b59b1f0b95990dfca298</id>
      <name>SqueezeLite</name>
      <category>default</category>
    Here is the string i am using to try to pass
    {"category":"default","id":"23a0c4d3a0b4b59b1f0b95990dfca298 "}
    Not sure the exact names of the parameters though
    Any thoughts?
    Here is an example that is said to work
    http://IPADDRESS:PORT/jsonrpc?request={"jsonrpc":"2.0","method":"Player.Open","par ams":{"item":{"file":"plugin://plugin.program.advanced.launcher/?CATEGORY/LAUNCHERID"}}}
    Not sure how i would use that in combination with the execute addon though
      Okay This works,
      Going to try the activate windows method
        any thoughts on getting this to work using the execute addon method would be awesome. Currently the open media method displays a window saying accessing stream
          did you try the "GUI Activate Window" action? it looks like this is what your link above recommend to use
          set Window=video
          and Sub-section=plugin://plugin.program.advanced.launcher?CATEGORY_ID/LAUNCHER_ID
            I got both methods working, thanks
