Does not connect
  • Does not connect
    Hi spud,
    I'm trying this plugin for the first time today, but although it does discover the Kodi player, it does not connect. Here's what's in the log:
    Mar-13 2:58:51 PM	 	XBMC	INFO Failed to connect to XBMC Client: BFR Kodi 192.168.1.197 Method not found: 'System.Threading.Tasks.Task`1 AsyncExtensions.GetRequestStreamAsync(System.Net.WebRequest)'.
    Mar-13 2:58:49 PM	 	XBMC	INFO Resolved Service: BFR Kodi - _xbmc-jsonrpc-h._tcp. - 192.168.1.197 - 80
    Mar-13 2:58:49 PM	 	XBMC	INFO Resolved Service: BFR Kodi - _xbmc-jsonrpc._tcp. - 192.168.1.197 - 9090
    Mar-13 2:58:49 PM	 	XBMC	INFO Found Service: BFR Kodi
    Mar-13 2:58:35 PM	 	Plug-In	Finished initializing plug-in XBMC
    Mar-13 2:57:37 PM	 	XBMC	INFO XBMC version 3.0.0.37
    Mar-13 2:57:36 PM	 	Info	Plugin XBMC has connected. IP:127.0.0.1:4384
    Mar-13 2:57:34 PM	 	Plug-In	Interface XBMC is running as a trial, 30 days remaining.
    Any ideas?
    Al
    HS 3.0.0.532: 1963 Devices 1141 Events
    Z-Wave 3.0.1.261: 122 Nodes on one Z-Net
    This is what debug logging shows when trying to connect:
    Mar-13 3:08:39 PM	 	XBMC	DEBUG System.MissingMethodException: Method not found: 'System.Threading.Tasks.Task`1 AsyncExtensions.GetRequestStreamAsync(System.Net.WebRequest)'. at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess(Task task) at HSPI_XBMC.XBMCPlayer.d__3.MoveNext()
    Mar-13 3:08:38 PM	 	XBMC	INFO Failed to connect to XBMC Client: BFR Kodi 192.168.1.197 Method not found: 'System.Threading.Tasks.Task`1 AsyncExtensions.GetRequestStreamAsync(System.Net.WebRequest)'.
    Mar-13 3:08:38 PM	 	XBMC	DEBUG Pinging on http port 80
    Mar-13 3:08:38 PM	 	XBMC	DEBUG Connecting on tcp port 9090
    Mar-13 3:08:38 PM	 	Device Control	Device: BFR Kodi Root to Connect (-1) by/from: CAPI Control Handler
    I can connect to the kodi box using a web browser from my hs pc.
      what version of .NET do you have?
      this plugin needs .NET 4.5 or later, if you can't install that because you are on XP, there is an old version of the plugin that works with .NET4 in this thread: http://forums.homeseer.com/showthread.php?t=174493
        Hi spud,
        Yes, I'm on XP so 4.0 is the latest I can install. I'll try the other version. What functionality is missing from it? I'm guessing that you won't be updating it or will you maintain it as well?
        Al
          you can see what has been added/fixed since version 3.0.0.29 in this post: http://board.homeseer.com/showthread.php?t=161818
          there is nothing critical, just small fixes and features addition
          I don't plan to update this .NET 4 version unless there is a lot of demand.
