Error updating to latest version
  • Error updating to latest version
    I just updated to the latest version via the plugin manager - after I updated, I now receive the following error:
    'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Warning, Error details with EXE HSPI_XBMC.exe: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Warning, Error details with EXE HSPI_XBMC.exe: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Warning, Error details with EXE HSPI_XBMC.exe: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Warning, Error details with EXE HSPI_XBMC.exe: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Warning, Error details with EXE HSPI_XBMC.exe: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Warning, Error details with EXE HSPI_XBMC.exe: Could not load file or assembly 'System.Threading.Tasks, Version=2.6.10.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
    Plugin no longer shows up in the plugin list...
    Thoughts?
    it looks like it's the same problem you had when you originally installed the plugin: http://board.homeseer.com/showthread.php?t=174206
    to fix this problem once and for all, as I said at the end of this thread, I would remove all the "bindingRedirect" lines that have been added to your machine.config file, i.e:
        <runtime><!-- UPDATE:03 -->
      <assemblyBinding xmlns = "urn:schemas-microsoft-com:asm.v1" >
         <dependentAssembly>
            <assemblyIdentity name="System.Runtime" publicKeyToken="b03f5f7f11d50a3a" culture="neutral"/>
               <bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0"/>
         </dependentAssembly>
         <dependentAssembly>
            <assemblyIdentity name="System.Threading.Tasks" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-2.6.10.0" newVersion="2.6.10.0" />
         <dependentAssembly>
            <assemblyIdentity name="System.Net.Http" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-2.2.29.0" newVersion="2.2.29.0" />
         <dependentAssembly>
            <assemblyIdentity name="System.Net.Http.Primitives" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
         <dependentAssembly>
            <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-7.0.0.0" newVersion="7.0.0.0" />
         <dependentAssembly>
            <assemblyIdentity name="Google.Apis" publicKeyToken="4b01fa6e34db77ab" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-1.9.3.19379" newVersion="1.9.3.19379" />
         <dependentAssembly>
            <assemblyIdentity name="Google.Apis.Core" publicKeyToken="4b01fa6e34db77ab" culture="neutral" />
         <dependentAssembly>
            <assemblyIdentity name="log4net" publicKeyToken="669E0Ddf0bb1aa2a" culture="neutral" />
            <bindingRedirect oldVersion="0.0.0.0-1.2.14.0" newVersion="1.2.14.0" />
      </assemblyBinding>
    </runtime>
      Thanks again - works perfectly!
