Just curious.
Does it run in Linux?
- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home AssistantTags: None
Originally posted by Pete View PostJust curious.
Sent from my XT1585 using Tapatalk
Thank you Frank.
I can test too if you want here.
Easiest to test is initially starting Homeseer 3 in Linux and manually running the plugin in a separate terminal session using the command mono plugin.exe.
The terminal window - console will show a bit a granularity and or any issues connecting to the core or nomenclature issues.
Historically I have seen just a few nomenclature issues between Windows and Linux plugins. The backward slash "\" versus the forward slash "/" stuff.
Running two HS3 machines here in Ubuntu 16.04 64 bit. One ARM and one Intel CPU and same Mono version 5.4X
Yesterday on a lark tested my Omni Pro / Samsung Omni Plugin / Amazon Alexa / Roku stuff and it worked. The Samsung Hub works indirectly with the Omni Plugin / OmniPanel. Current posted Samsung Roku plugin works only with a running iOS or Android smart phone plugin.
Curious where the name MeiKu came from?
Here kept (not using these days) the original Roku media box (really all audio). Same as a bunch of old audio stuff (like my Nakamichi Dragon or Marantz SD-9000)Last edited by Pete; December 9, 2017, 12:29 PM.- Pete
I had a quick go with the plugin on Linux. I got an error "Warning, Cannot load EXE (possibly missing dependencies). Could be down to "\" vs "/" when trying to find some of the dlls. I've written a couple of plugins in the past and got them to run in both Windows and Linux. If I can help in any way, let me know!
-David
Originally posted by drule View PostI had a quick go with the plugin on Linux. I got an error "Warning, Cannot load EXE (possibly missing dependencies). Could be down to "\" vs "/" when trying to find some of the dlls. I've written a couple of plugins in the past and got them to run in both Windows and Linux. If I can help in any way, let me know!
-David
You were right though. The plugin in the updater won't load because of the "/" vs "\" in the config file (you could fix it manually, but then the plugin will fail to add the status images for the apps in the version in the updater).Last edited by sirmeili; December 15, 2017, 01:42 PM.
