Configuration file
  • Configuration file
    Hi -- been using this plugin for a few weeks and it is great! One question -- I have a couple of Roku devices that have changed IPs since initially discovered by the plugin. Every time I restart HS3, the plugin reverts to the discovered IP. I have tried looking in the various related config files and can't seem to locate where the plugin is storing its config information. Can anyone point me in the right direction? I'd like to specify the IP for my device manually, if that's possible.
    Thanks!
    hjk
    As I mentioned in the other thread, sorry I missed this thread. If you "discover" new rokus and it finds them again, it should update and save the settings (without you having to manually update the IP).
    Like I said in the other thread though, I will do some tests on this and get back to you later this week. I have to travel a bit for work the middle of this week, so it will be a few days until I can really look into this, but I will.
    Frank
