I have 4 Roku units three ultra and one premiere. Two are connected hard wire to the network and two are connected via wifi. All of the units are setup with a static ip address. The problem I am having is that the two that are setup via wifi periodically go offline and when this happens they don't respond to commands.
Is this the expected behavior and is there any way to wake them up so they can then be controlled. Can you think of any reason that would make them go offline?
If I restart the Roku it will then come back online for a while.
Help would be appreciated. Otherwise the plugin is working very well.
Mike
Mike
