Status not updating.
    I really need some help on this.
    I have deleted all my roku's and tried to start over to no avail.
    I can control the roku from HS but the active app does not update.
    Sent from my SM-T820 using Tapatalk
    Resolved after deleting all, uninstalling and reinstalling plugin. Grrr....with 9 rokus it was a pain to redo all events.
      IF it is like me, the problem will shows up gain.
      Any idea sirmeili ?
        Could it be the ip changed? I'll check the code or try and add more debugging to determine the issue tonight and release a beta.
        Sent from my Pixel 2 XL using Tapatalk
          yes one time, 3 months ago.
          I have no events configured with this plugin yet. So will create new devices for my 3 rokus , to rule this out.
            I have two roku activated. I can't test one of them now. But the other one do not works at all. I sent you the log
              I have mac address reservations. Also, I could control the roku from hs but the apps and status was not updating.
              Sent from my SM-N950U using Tapatalk
                I checked your Logs. It seems to time out waiting for a response from the roku. I will see if I can set the timeout to a longer time, but it also appears as though you are polling every 5 seconds. I would change that to 10 seconds. I've never gone faster than that
                kff If you get that issue again, please send me logs. If I can't see what is wrong from the logs, I can most likely add more logging.
                  Ok thanks . I don’t remeber changing the polling time but I will set it on 10 on the mext version.
