MeiKu (Roku Monitor and Control) version 3.2.0.2 (beta) is now available!
  • MeiKu (Roku Monitor and Control) version 3.2.0.2 (beta) is now available!
    MeiKu v3.2.0.2 (Beta) is now available in the HomeSeer store and in the updater! (found in the beta section)
    The following are included:
    • Logging was ignoring settings (that what I get for only testing with logging turned on)
    • Fixed issue with roku list refreshing before discovery was complete. If a device isn't found, try refreshing before adding by IP. I need to revisit this.
    This has been stable for me, but I wanted to beta it first. If after the weekend I don't hear any complaints, it will be released as the main release. No new features, but I wanted to do the rewrite first.
    Please see the full descriptions here:
    https://forums.homeseer.com/showthread.php?t=188175
    Release notes Here:
    https://forums.homeseer.com/showthread.php?t=188176
    And request new features here:
    https://forums.homeseer.com/showthread.php?t=188177
    MeiAutomtion Home
    Thanks Frank, I tried this version:
    Discovery works,
    Status works for the first devices and second devices.
    Control works for the second devices.
    Control does not work for the third and fourth device.
    I do not have a headphone device. Do I need to plug headphones in my remote?
      Installed this beta version. After enabling the plugin I get the following error message every 2 minutes:
      Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object.;
      Disable the plugin and the errors stop, Re-enable the plugin and the messages continue. I will grab a debug log and post it later tonight.
        I also have this error multiple times ( some are from v3.2.0.0)
        Mar-14 22:55:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:53:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:51:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:48:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:46:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:44:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:40:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:39:53 Error There was a problem trying to send the command to launch an app. The remote server returned an error: (404) Not Found.
        Mar-14 22:39:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:38:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:37:24 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:37:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:36:07 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:36:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:35:16 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:35:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:34:51 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:27:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:26:44 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:17:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:16:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:15:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:14:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:13:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:12:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:11:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 22:05:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:57:34 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:57:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:56:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:55:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:54:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:53:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:52:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:51:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:50:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:47:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:44:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:42:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:40:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:38:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:36:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:35:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:34:28 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:34:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:33:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:32:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:31:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:30:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:29:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:27:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:25:57 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:24:57 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:24:00 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:23:20 Error Error during HSEVENT: EventType: CONFIG_CHANGE; Param cnt: 6 Message: Object reference not set to an instance of an object;
        Mar-14 21:19:57 Error Unexpectedly Failed during plugin startup: Object reference not set to an instance of an object
        Mar-14 21:19:57 Error There was a problem trying to get installed apps. Error: ConnectFailure (No route to host)
          Yup, that is fixed and the headphone issue is fixed. If you still have the headphone issue, delete the device where the commands are NOT in a pop up and restart the plugin.
          Also fixed is the commands not working.
          Beta 3.2.0.3 is out.
          MeiAutomtion Home
            Removed all device before updating *
            yes the headphone issue is resolved. Now only one device is created with a dropdown menu.
            I was able to send a command one time. I tried another one but it didn't work.
            I did check my log and there were errors. So i removed the roku from hs3. and tried to add it back. But now I can't find it by ip ( or discovery).
            Mar-14 23:32:37 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:32:37 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:32:32 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:32:32 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:30:50 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:30:50 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:30:45 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:30:45 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:30:35 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:30:35 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:29:18 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:29:18 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:28:53 Error The device may not be a roku device at location: http://192.168.1.XXX:8060/. Please check the device is accessible.
            Mar-14 23:28:53 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:28:35 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:28:30 Error There was a problem trying to get the active app at location http://192.168.1.XXX:8060/. Error: The operation has timed out.
            Mar-14 23:27:44 Error There was a problem trying to send a keypress. The operation has timed out.
            Mar-14 23:27:35 Error There was a problem trying to get the device info. The operation has timed out.
            Mar-14 23:27:30 Error There was a problem trying to get the active app at location http://192.168.1.XXX:8060/. Error: The operation has timed out.
            Mar-14 23:26:51 Error There was a problem trying to send a keypress. The operation has timed out.
            Sending a http post command still works... So I do not know why The plugin do not see my roku anymore.
              Restarted the plugin. Was able to see the roku again.
              Created devices and tried to control. It worked two times. But after, no luck.
              Mar-14 23:45:55 Error There was a problem trying to get the device info. The operation has timed out.
              Mar-14 23:45:51 Error There was a problem trying to send a keypress. The operation has timed out.
              Mar-14 23:45:50 Error There was a problem trying to get the active app at location http://192.168.1.xxx:8060/. Error: The operation has timed out.
              Mar-14 23:45:05 Error There was a problem trying to send a keypress. The operation has timed out.
              Mar-14 23:44:55 Error There was a problem trying to send a keypress. The operation has timed out.
              Mar-14 23:44:55 Error There was a problem trying to get the device info. The operation has timed out.
              Mar-14 23:44:50 Error There was a problem trying to get the active app at location http://192.168.1.xxx:8060/. Error: The operation has timed out.
                sirmeili
                I removed all the devices ( also the one that holds the ped data I think).
                Deleted all the files
                Redownloaded 3.2.0.3
                But now I have this error every time I try to go to the config page.
                  Installed 3.2.0.3 and no more errors. Haven't tried controlling my roku yet - will do that tomorrow.
                    Maybe it is a filepath problem on linux ?
                    Mar-15 00:33:00 Info Page Meiku_Config
                    Mar-15 00:32:41 Info Page Meiku_Config
                    Mar-15 00:32:18 Plug-In Finished initializing plug-in MeiKu
                    Mar-15 00:32:18 Starting Plug-In MeiKu loaded in 800 milliseconds
                    Mar-15 00:32:18 Starting Plug-In Plugin MeiKu started successfully in 531 milliseconds
                    Mar-15 00:32:18 Info Plugin started on version: 3.2.0.3
                    Mar-15 00:32:18 Error Unexpectedly Failed during plugin startup: Object reference not set to an instance of an object
                    Mar-15 00:32:18 Info Registering Actions.
                    Mar-15 00:32:18 Info Registering Devices.
                    Mar-15 00:32:18 Info Registering Web Pages.
                    Mar-15 00:32:18 Starting Plug-In Initializing plugin MeiKu ...
                    Mar-15 00:32:18 Info Connection to homeseer successful.
                    Mar-15 00:32:18 Info Plugin MeiKu has connected. IP:127.0.0.1:41142
                    Mar-15 00:32:08 JowiHue Correcting port for bridge Conbee USB
                    Mar-15 00:31:32 Updater Install/Update of package MeiKu Roku Monitor and Control was successful.
                    Mar-15 00:31:32 Updater Extraction Complete.
                    Mar-15 00:31:32 Updater Extracting files from zip file: /HomeSeer/Updates3/MeiKu Roku Monitor and ControlBETA 3.2.0.3/status_images.zip Destination: /HomeSeer/html/images/Meiku/status/
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/Serilog.Sinks.File.dll
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/Serilog.dll
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/SSDP.Library.dll
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/Newtonsoft.Json.dll
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/CommandLine.dll
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/ADODB.dll
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/bin/Meiku/MBPlugins.dll
                    Mar-15 00:31:32 Updater Making dir: /HomeSeer/bin/Meiku/
                    Mar-15 00:31:32 Updater Copying file: /HomeSeer/HSPI_Meiku.exe.config
                    Mar-15 00:31:32 Updater Installing package MeiKu Roku Monitor and Control
                    Mar-15 00:31:32 Updater Update downloaded successfully
                    Mar-15 00:31:31 Updater Downloading update: MeiKu Roku Monitor and Control
                    Mar-15 00:31:31 Warning Update is not configured properly in updater.txt file, missing interface name.
                    Mar-15 00:31:31 Updater Starting download of updates
                    This is my html folder ( two image/Image folder ).
                      If it works for other, it is ok for me, I just wanted to help. I can use the http post command as before.
                      For my part , I will wait , for when you have time to put the config in a file instead of using a device. Maybe that was an issue here?
                      Thanks Matt
                        Thanks Matt
                        I'll put it on my linux machine. It should be working just fine though. I am no longer using the HS way of determining if it's Linux or not and am using built in .net methods now as I was getting sick of having to pass the HS object around.
                        Either way, we'll get it fixed for you, MattL0 !
                        MeiAutomtion Home
                          Thanks Matt
                          Matt,
                          Can you try 3.2.0.4? I think I fixed your issues
                          MeiAutomtion Home
                            Hi Frank , I Have the same issue as in post 8.
                            Mar-15 17:45:10 Info Plugin started on version: 3.2.0.3
                            Mar-15 17:45:10 Error Unexpectedly Failed during plugin startup: Object reference not set to an instance of an object
                            Mar-15 17:45:10 Info Registering Actions.
                            Mar-15 17:45:10 Info Registering Devices.
                            Mar-15 17:45:10 Info Registering Web Pages.
                            Mar-15 17:45:10 Starting Plug-In Initializing
                              I know that the last time I used the plugin was when I was on windows .1 years ago.
                              Maybe something good to know ?
