Upgrade related Meiku disconnect
    I recently migrated to HS4, (now on newest build 4.1). I also upgraded to the newest Meiku release. Now, none of the HSTouch created commands for Meiku function. I believe it is some type of device identification issue but am not sure where to look next. Below are the Meiku specific log entries. What do I need to do to point to the proper device version?
    7/09/2020 11:53:56 HomeSeer Warning Device (927) MeiKu MeiKu MeiKu - Headphones does not reference a parent, it should reference one parent
    7/09/2020 11:53:56 HomeSeer Warning Issue checking child device (927) MeiKu MeiKu MeiKu - Headphones
    7/09/2020 11:53:56 HomeSeer Warning Device (926) MeiKu MeiKu MeiKu - Control does not reference a parent, it should reference one parent
    7/09/2020 11:53:56 HomeSeer Warning Issue checking child device (926) MeiKu MeiKu MeiKu - Control
    7/09/2020 11:53:56 HomeSeer Warning Device (925) MeiKu MeiKu MeiKu - Active App does not reference a parent, it should reference one parent
    7/09/2020 11:53:56 HomeSeer Warning Issue checking child device (925) MeiKu MeiKu MeiKu - Active App
    7/09/2020 11:53:56 HomeSeer Warning Device (927) MeiKu MeiKu MeiKu - Headphones is marked as child, but does not reference any parent
    7/09/2020 11:53:56 HomeSeer Warning Issue checking parent device (924) MeiKu MeiKu MeiKu -
    7/09/2020 11:53:56 HomeSeer Warning Device (926) MeiKu MeiKu MeiKu - Control is marked as child, but does not reference any parent
    7/09/2020 11:53:56 HomeSeer Warning Device (925) MeiKu MeiKu MeiKu - Active App is marked as child, but does not reference any parent
    7/09/2020 11:53:55 HomeSeer Plug-In Finished initializing plug-in MeiKu
    7/09/2020 11:53:55 HomeSeer Starting Plug-In MeiKu loaded in 5400 milliseconds
    7/09/2020 11:53:51 HomeSeer Starting Plug-In Plugin MeiKu started successfully in 1561 milliseconds
    7/09/2020 11:53:50 HomeSeer Starting Plug-In Initializing plugin MeiKu ...
    7/09/2020 11:53:50 HomeSeer Info Plugin MeiKu has connected. IP:127.0.0.1:62764
    7/09/2020 11:53:27 HomeSeer Plug-In Found plug-in: MeiKu, version: 3.2.0.9
    I have an issue in the newest version where the "control" device gets a setting set wrong. I'm releasing a fix tonight.
      Ok, sorry, I thought this was another issue. How old is your install of MeiKu?
      (though I think your issue wiht your commands is fixed in 3.2.0.10, it's not related to those log entries)
        I noted the 3.2.0.10 upgrade. I was on 3.2.0.09. I disabled the plugin, upgraded, and restarted it. Things are... bizarre. The when I go to the device list I can execute control commands. When I attempt to use the pre-existing HSTOUCH interface, the only thing that works ... is the BACK command. I have no directional functions, no select... nothing. This is the device list.
          Any help would be appreciated.... I had forgotten how complicated it had gotten getting multiple HDMI sources configured and really like using your plugin to control my ROKU.
            I'm not familiar with HS4 yet. Are you saying the commands work from the HS web UI, but not from HSTouch?
              Correct. In HS4, on the devices page, I am able to control my ROKU using the devices created by the Meiku plugin. My HS3Touch designed UI functioned under HS3 with previous Meiku plugin version. I upgraded my Meiku plugin as the last step in my migration to HS4. The really confusing thing is that the "back" command functions from the HS3Touch created UI... I am confused as to why one command would work and others stop when nothing changed in the UI and the commands are the same.
                Of note, I have also tried a rescan to hopefully refresh apps and commands.
                  Ok... understanding I consider myself a novice... I opened HSTouch Designer made a copy of my past functional UI, and started modifying my ROKU screen. I assigned icons to other devices (like amp volume) saved them, tested the change, then went back in and started reassigning back to their ROKU functions.... and am having some success. UP, DOWN, and some of the Active App options are working. I will continue to mess with it but, it seems that there is some linkage to legacy device IDs... ot something... dunno.
                    Ok, it seems like an upgrade issue to HS4 or and HSTouch issue, but i"m glad you figured it out.
                    BTW...Howdy Neighbor! (see you're in Tampa I'm about 2 hours away)
                      Sebring... nice place... great race...
                      So, I have goofed around with this and again verified that all commands seem to work when executed from the Homeseer Device page (HS4) however buttons defined to change the active app and control fast forward and rewind do not. The play/pause function does work.
                      So do you think I should post this under the HSTouch thread? I am almost positive they will tell me it is a plugin issue. What can I do to move things forward?
                        I can add logging to show when button presses are sent to the plugin to send to the Roku. This way we can see if the plugin is getting the commands or not. I'll push something out this week, for you.
                          So Neighbor, glad you are looking into this and I hope you have success. Sorry for the slow response. I only have occasional success in getting the Meiku plugin to function. It will most often function from the webpage and on rare occasions via HSTouch. I am at a loss.
                            Just checking in... problem remains.
                              Hope all is well with you. You helped me in the past when the Meiku plugin became unreliable. Based on our past exchange, there seemed to be an issue when I applied one of the Homeseer HS4 upgrade. At that time, it seemed to be related to how HSTouch was functioning. I could execute the Meiku (Roku) commands from the Homeseer webpage but, the same commands did not work with HSTouch. Well, I recently applied the HS4 (4.2.8.0) and now I cannot execute any commands using the Meiku plugin. The Meiku commands are not functioning from the webpage nor the HSTouch UI.
                              I have looked on the forum and did not see any new entries on this. Please advise when you can. Currently when I use HSTouch to switch over to the Roku, I must then use the Roku remoteā€¦ irritating but I can make it work until I hear from you. Thanks.
