error in LOG "there was a problem trying to send the command to lunch"
    As per the title, I often have the following in the Log:
    7-25-2020 06:40:07 MeiKu Error There was a problem trying to send the command to launch an app. Une erreur s'est produite lors de l'envoi de la demande.
    I have an event that when movements are detected it starts a monitor and that does not work . It looks the only way to fix the issue is to reset the ROKU tv at the other hand. Bizarrely, If I connect with my Iphone I can see the Roku TV and I can manage it even when I have this messake from Meiku
    meiku version installed 3.2.0.10
    Any idea where I should look ?
    Not sure. I checked the code and translated your error. It just says it couldn't send the request. it's weird that it won't do it. What is the command you are sending? Is it power on?
