a nill instance was returned
  • a nill instance was returned
    Dirk,
    After upgrading to HS3 3.0.0.425 I keep getting groups of errors every 5 minutes in the log regarding the Sonos plugin:
    apr-12 14:45:58	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_B8E937DE13DA01400
    apr-12 14:45:48	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_5CAAFDF5FDE201400
    apr-12 14:45:38	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_B8E937DB2DDE01400
    apr-12 14:45:28	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_5CAAFDF5F07401400
    apr-12 14:45:00	 	regenkans	er valt 0,1 mm/u om 14:55
    apr-12 14:40:56	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_B8E937DE13DA01400
    apr-12 14:40:46	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_5CAAFDF5FDE201400
    apr-12 14:40:35	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_B8E937DB2DDE01400
    apr-12 14:40:25	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_5CAAFDF5F07401400
    apr-12 14:40:00	 	regenkans	er valt 0,21 mm/u om 14:40
    apr-12 14:39:38	 	Event	Event Trigger "Tuin Tuinpomp uit"
    apr-12 14:35:53	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_B8E937DE13DA01400
    apr-12 14:35:43	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_5CAAFDF5FDE201400
    apr-12 14:35:33	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_B8E937DB2DDE01400
    apr-12 14:35:23	 	Sonos Error	Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance was returned for UDN = uuid:RINCON_5CAAFDF5F07401400
    Any idea what might be causing this?
    Wim
    -- Wim
    I had problems after the latest windows 10 update. it did the update while I was away, killed homeseer and corrupted everything, wiped out all my zwave devices and gave me errors on a reboot with sonos. lucky and thanks to blade I had a good backup. I restored with the backup, rebooted and everything was fine. updated to the latest .425, and did another backup. I hope setting windows 10 to a metered connection stops the updates until I am ready....
      That is not the case here. No devices were erased today. But it appears that after the upgrade of HS3 the sonos plugin has created double root devices. I have stopped the plugin here, removed the doubles and deleted the ini file.
      Then with a restart of the plugin the errors were gone again and all seems to function normal again.
      Guess there has been a hickup during the upgrade?
      Wim
      -- Wim
        I am having the same problem. How did you know which instance of the player to delete? Or does it matter?
          Never delete players from the HS devices management page!
          Make sure you are on the 3.1.x.x PI version not the end-of-life'd 3.0.x.x. stream (because delete players is broken there due to post release changes in HS)
          Assuming you are on 3.1.x.x release stream, I would delete the player from the plugin's config page in the device player table. If you had events (on the original players), they are corrupted anyway so if you delete the wrong player and it comes back, delete both and the player will be rediscovered and come back and that should be the end of it (I think!).
          If not:
          Stop hs
          delete sonos.ini file
          restart hs
            Im seeing the same thing. I wound up resetting everything, creating new devices (after fresh .ini file etc). All was good but today my log is again flooded with "Error in CreateOneSonosController while instantiating the SonosPlayerInfo a nill instance" Now the plugin shows the correct zones and everything seems to be working, so the error feels noise but wanted to let you know...
              Could you turn debug on, restart HS, capture log and post here together with .ini file?
                You got it, I probably won't be able to do this until tomorrow, but I'll posts here as soon as I can.
                  Question; I assumed you meant a text log file created by the plugin. I enabled debug, super debug, and log to file. Rebooted but I cant find a log file associated with the plugin, I turned off log to file and rebooted and have plenty of log messages in the HS log, but not sure how to capture that?
                    Don't enable superdebug, just debug.
                    The log file is created under <hsroot>\html\sonos\logs but only written to when you turn the logging to disk off.
                    So here are the steps:
                    a/ HS is running
                    b/ turn PI debug on and logging to disk
                    c/ restart hs
                    d/ wait until restart and init is complete
                    e/ turn logging to disk off
                    f/ go to <hsroot>\html\sonos\logs
                    g/ upload log to posting
                    Dirk
                      Attached is the zipped log file and my ini file. Good hunting!
                        any chance to post your player table
                          Here is a printout of the full settings page...
                            another question: are you on the sonos beta program or running release sonos SW?
                            I see so many errors in the log, never ever seen that on a simple GetZoneGroupState
                              While I am a Sonos beta member, I am not currently running a beta. I am on 9.1 release build 45156150
                              Sonos about info:
                              Associated ZP: 10.1.3.126
                              Boost: Boost Living
                              Serial Number: B8-E9-37-0C-58-CA:0
                              Version: 9.1 (build 45156150)
                              Hardware Version: 1.12.1.2-1
                              Series ID: A100
                              IP Address: 10.1.3.100
                              WM: 0
                              Boost: Boost Screening
                              Serial Number: B8-E9-37-0E-5C-96:5
                              Series ID: A100
                              IP Address: 10.1.3.143
                              WM: 0
                              Play:3: Breakfast Room
                              Serial Number: 00-0E-58-F8-AF-C0:6
                              Hardware Version: 1.8.1.2-1
                              Series ID: A100
                              IP Address: 10.1.3.106
                              WM: 0
                              OTP:
                              Play:5: Casita Living
                              Serial Number: 00-0E-58-55-11-CA:1
                              Hardware Version: 1.16.4.1-1
                              Series ID: P100
                              IP Address: 10.1.3.130
                              WM: 0
                              OTP: 1.1.1(1-16-4-zp5s-0.5)
                              ZP80: Deck Lower
                              Serial Number: 00-0E-58-20-16-22:6
                              Hardware Version: 1.1.16.3-1
                              Series ID: S100
                              IP Address: 10.1.3.123
                              WM: 0
                              r8: 16.0-7
                              Connect:Amp: Deck Upper
                              Serial Number: 00-0E-58-30-FF-32:G
                              Hardware Version: 1.16.3.1-1
                              Series ID: P100
                              IP Address: 10.1.3.117
                              WM: 0
                              OTP: 1.1.1(1-16-3-0.9)
                              Play:3: Dining Room
                              Serial Number: 00-0E-58-71-94-B6:4
                              Series ID: A100
                              IP Address: 10.1.3.103
                              WM: 0
                              OTP:
                              ZP80: Game Room
                              Serial Number: 00-0E-58-20-18-14:B
                              Series ID: S100
                              IP Address: 10.1.3.122
                              WM: 0
                              r8: 16.0-7
                              Connect:Amp: Great Tree
                              Serial Number: 00-0E-58-3A-B9-44:8
                              Series ID: P100
                              IP Address: 10.1.3.132
                              WM: 0
                              Play:1: Guest Upper 1
                              Serial Number: B8-E9-37-5F-5E-DC:5
                              Hardware Version: 1.8.3.7-1
                              Series ID: A101
                              IP Address: 10.1.3.110
                              WM: 0
                              OTP:
                              Play:1: Guest Upper 2
                              Serial Number: 5C-AA-FD-6D-4C-06:2
                              Series ID: A101
                              IP Address: 10.1.3.111
                              WM: 0
                              OTP:
                              Play:1: Gym Bathroom
                              Serial Number: B8-E9-37-B6-71-14
                              Series ID: A101
                              IP Address: 10.1.3.124
                              WM: 0
                              OTP:
                              Play:3: Kitchen
                              Serial Number: 00-0E-58-7B-82-DA:F
                              Series ID: A100
                              IP Address: 10.1.3.105
                              WM: 0
                              OTP:
                              Play:5: Living Room
                              Serial Number: 00-0E-58-81-28-F8:C
                              Series ID: P100
                              IP Address: 10.1.3.102
                              WM: 0
                              Connect:Amp: Main House Front
                              Serial Number: 00-0E-58-3A-B9-00:8
                              Series ID: P100
                              IP Address: 10.1.3.101
                              WM: 0
                              Play:1: Massage Room (L)
                              Serial Number: B8-E9-37-EB-A1-EC:7
                              Series ID: A101
                              IP Address: 10.1.3.125
                              WM: 0
                              OTP:
                              Play:1: Massage Room (R)
                              Serial Number: B8-E9-37-EA-E5-98:7
                              Series ID: A101
                              IP Address: 10.1.3.126
                              WM: 0
                              OTP:
                              One: Master Bathroom
                              Serial Number: 78-28-CA-05-CE-40:1
                              Hardware Version: 1.21.1.8-1
                              Series ID: A100
                              IP Address: 10.1.3.139
                              WM: 0
                              Playbar: Master Bedroom
                              Serial Number: 00-0E-58-BF-DF-24:B
                              Hardware Version: 1.9.1.10-1
                              Series ID: A100
                              IP Address: 10.1.3.112
                              Audio In:
                              WM: 0
                              OTP:
                              Sub: Master Bedroom
                              Serial Number: 5C-AA-FD-80-9E-D6:5
                              Hardware Version: 1.8.2.5-1
                              Series ID: A100
                              IP Address: 10.1.3.113
                              WM: 0
                              OTP:
                              Play:1: Master Sun Room (L)
                              Serial Number: B8-E9-37-54-15-5C:E
                              Series ID: A101
                              IP Address: 10.1.3.115
                              WM: 0
                              OTP:
                              Play:1: Master Sun Room (R)
                              Serial Number: B8-E9-37-55-49-DA:6
                              Series ID: A101
                              IP Address: 10.1.3.114
                              WM: 0
                              OTP:
                              ZP100: Pool
                              Serial Number: 00-0E-58-10-92-14:F
                              Hardware Version: 1.1.3.2-1
                              Series ID: S100
                              IP Address: 10.1.3.135
                              WM: 0
                              m16: 1.0-12170 r8: 0.8-16
                              ZP100: Pool Spa
                              Serial Number: 00-0E-58-10-39-A4:2
                              Hardware Version: 1.1.3.0-1
                              Series ID: S100
                              IP Address: 10.1.3.136
                              WM: 0
                              Playbar: Screening Room
                              Serial Number: 00-0E-58-B1-CF-69:G
                              Series ID: A100
                              IP Address: 10.1.3.121
                              Audio In:
                              WM: 0
                              OTP:
                              Play:5: Small Bar
                              Serial Number: 00-0E-58-52-53-BA:E
                              Series ID: P100
                              IP Address: 10.1.3.104
                              WM: 0
                              Play:1: TV Room (R)
                              Serial Number: 78-28-CA-6F-DB-34:6
                              Hardware Version: 1.20.1.6-1
                              Series ID: A200
                              IP Address: 10.1.3.138
                              WM: 0
                              Play:1: TV Room (L)
                              Serial Number: 78-28-CA-6F-DB-3C:E
                              Series ID: A200
                              IP Address: 10.1.3.137
                              WM: 0
                              Play:3: TV Sun Room
                              Serial Number: 00-0E-58-F8-34-96:B
                              Series ID: A100
                              IP Address: 10.1.3.108
                              WM: 0
                              OTP:
                              Play:1: Wine Cellar
                              Serial Number: 5C-AA-FD-6D-4D-46:G
                              Series ID: A101
                              IP Address: 10.1.3.118
                              WM: 0
                              OTP:
