Radio from TuneIn does not resume on TTS announcement via Event
    Just tried TTS via Events.
    I noticed, that if I play a song from a library, it resumes after the announcement.
    But if I was playing a radio from TuneIn, after the announcement, radio station is back on track, but have to manually trigger play button on Sonos App.
    Is there a workaround for this?
    Also, how do you manage to play a some chime just before the announcement, is there an easy way?
    Thanks.
    Thanks.
    Which PI version are you on? Which OS? Can you post screenshot of your events. Consult the help file (click (tools->help->Sonos) on how to do chimes before or after announcement.
    Dirk
      Hi Dirk,
      Sorry for not being concrete. I am new here. What is PI ? I often find it in comments.
      Some info:
      Sonos Plugin 3.1.0.24
      System:
      Current Date/Time: 8/13/2018 7:21:40 PM
      HomeSeer Version: HS3 Pro Edition 3.0.0.435
      Operating System: Microsoft Windows 10 Home - Work Station
      System Uptime: 2 Days 20 Hours 3 Minutes 53 Seconds
      IP Address: 192.168.1.207
      Number of Devices: 653
      Number of Events: 27
      Available Threads: 200
      HSTouch Enabled: True
      Event Threads: 0
      Event Trigger Eval Queue: 0
      Device Exec Queue: 0
      HSTouch Event Queue: 0
      Email Send Queue: 0
      Enabled Plug-Ins
      1.3.3.0: Device History
      3.0.0.48: EasyTrigger
      3.9.610.5: HSBuddy
      2.0.2.5: JowiHue
      3.1.0.24: Sonos
      3.0.6159.37431: UltraNetatmo3
      3.0.6175.15900: UltraNetatmoWelcome3
      3.0.1.190: Z-Wave
      Event:
      http://prntscr.com/ki4ivc
      Linkgroup:
      http://prntscr.com/ki4j2w
      Player Table:
      http://prntscr.com/ki4j7z
      Hope above helps.
      BTW I played more.
      Sometimes Radio resume playing, but seems on random.
      And when resume, often it is another Radio Station, but not the last I used to play.
        Hi Dirk,
        Some info:
        System:
        Event Threads: 0
        Email Send Queue: 0
        Enabled Plug-Ins
        3.9.610.5: HSBuddy
        2.0.2.5: JowiHue
        3.1.0.24: Sonos
        3.0.1.190: Z-Wave
        Event:
        Linkgroup:
        Player Table:
        Hope above helps.
        BTW I played more.
        Thanks for the info, it all looks good nothing that jumps out. I see you have the same issue with living room player showing up multiple time, the only thing could be that you are picking a player, either as source or destination, that would be a good choice. The S9 would be a good choice, a paired S1 to an S9 would be a bad choice.
        Could you turn the PI (PlugIn) debug flag on, turn disk logging on, do the announcement that has the wrong station playing, turn off the disk-log-flag (important!!!) and post the log file which you can find under <hs root>\html\sonos\Logs
        Dirk
