HS3-Linux install issue
  • HS3-Linux install issue
    I've been evaluating HS3 on Linux (Raspberry Pi). When installing Sonos plugin 3.1.0.24, following appears in log, and the help is not installed.
    Sep-12 10:30:49 PM           Updater     Extracting files from zip file: help.zip
    Sep-12 10:30:49 PM           Error     Bad filename of /opt/HomeSeer/Updates3/Sonos3.1.0.24/help.zip passed to UnZip function.
    Contents of installer archive:
    $ unzip -l Sonos3_1_0_24.zip
    Archive:  Sonos3_1_0_24.zip
      Length      Date    Time    Name
       564301  10-03-2015 08:09   bin.zip
      1070444  08-05-2018 10:38   Help.zip
      1250304  08-05-2018 10:24   HSPI_Sonos.exe
         1538  12-24-2014 16:30   HSPI_Sonos.exe.config
       831655  12-21-2014 01:06   images.zip
          251  10-03-2015 08:10   install.txt
      3718493                     6 files
    install.txt contents:
    ,[CHECKVERSION],3.0.0.149
    HSPI_Sonos.exe,.,0
    HSPI_Sonos.exe.config,.,0
    ,[DELFILES],.\html\Sonos\Help
    help.zip,[UNZIPOVER],.\html\Sonos\Help
    images.zip,[UNZIP],.\html\images\Sonos
    ,[DELFILES],.\html\Sonos\bin
    bin.zip,[UNZIPOVER],.\html\Sonos\bin
    Note case mismatch "Help.zip" in Sonos3_1_0_24.zip vs. "help.zip" in install.txt. As Linux pathnames are case-sensitive, this seems the likely culprit.
    3718493 6 files
    HSPI_Sonos.exe,.,0
    wow, nice catch. I'll have a look at it and let you know outcome.
    Dirk
      In the meantime please can you post a link to a copy of the help file?
        At the top of the page on your HomeSeer look at Tools>Help it is under Sonos.
        Randy Prade
        Aurora, CO
        Prades.net
          Hi Randy, That’s the point, it isn’t installed! So not available and I can’t find a working link.
            I probably should have read the thread
            I have attached the help files here, it is HTML with supporting files. On a Windows installation it is under html\Sonos\Help. It should be in the same relative place on Linux.
            Randy Prade
            Aurora, CO
            Prades.net
              Thanks!
                New version of Sonos PI was submitted to updater yesterday, should be posted soon.
