Sonos voice
  • Sonos voice
    Hi, I've installed the sonos plugin hours ago.
    I have a problem:
    There is a German sapi5 voice named "Steffi" installed on my HS3 machine.
    My HS speaker client is set to German voice "Steffi" and my PC's sound card plays this voice.
    If I run a HS event to SONOS speak my Sonos doesn't speak the voice "Steffi" - it speaks another voice with English accent.
    Is there a possibility to change the Sonos plugin settings to let SONOS the voice "Steffi" ?
    Fischi
    do a search on this forum. Plenty of postings on how and issues. I think first and foremost if this is a 64 bit versus 32 bit voice, I think it won't work with HS. Other than that you can embed SAPI tags in your speak command, just browse this forum.
      That is odd. Sonos should use the same voices as the built in speaker client. There have been several people who were selecting 64-bit voices via the default Windows 10 SAPI control panel, where HS3 uses 32-bit voices. I wrote about it here. If yours is actually peaking in a different voice over Sonos, than from the HomeSeer speaker client, I don't know how that can happen.
      Randy Prade
      Aurora, CO
      Prades.net
        Dirk,
        can you give me an example for embedding sapi tags into a speak something event ?
          The speaker client settings have no effect on the Sonos plugin. The default voice used by the Sonos plugin is the default voice (32-bit) set in Windows on the machine running HS3. To set this, on the machine running HS3:
          Open Windows Start Menu, scroll to bottom of list, click 'Windows System' then 'Control Panel'.
          Select 'Ease of Access' then 'Speech Recognition'
          On the left side select 'Text to Speech'. Speech Properties pane opens
          Under voice selection, choose the voice you want.
            Originally posted by Fischi View Post
            Dirk,
            Here you go:
            <voice required="name = Microsoft David Desktop">The house lights will turn off in ten minutes
            <voice required='name = Microsoft David Desktop'>Hey<silence msec='1500'/>Daddy is home
            Randy Prade
            Aurora, CO
            Prades.net
              Here you go:
              Thanks, this works,
              Is there a tag for the speak speed and the volume ?
              Fischi
                There are tags, but they all don’t work in HomeSeer.
                https://supportdesk.win911.com/suppo...text-to-speech
                Randy Prade
                Aurora, CO
                Prades.net
                  Today I've ordered and installed a sapi5 voice from Cereproc named "Alex" (not Alexa :-)
                  This is running very good without the tags.
                  Also using replacement variables is running very good.
                  Fischi
