Sonos error on restart of HS3
  • #16
    Try turning on Load plugins in the background under setup - labs. That solved the problem for me.
    • #17
      I reverted back to prior version.
      tenholde
      • #18
        Originally posted by tenholde View Post
        I just updated to 489 to get debugging code for Event Registration Q full messages. Now getting what looks like the same issue:
        Initializing plug-in(2): Sonos Instance::Object reference not set to an instance of an object. Service Version: NO_VERSIONSTACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
        Can I suggest you add try/catch around your HS.* and Callback.* calls made at least in InitIO, this will help us track down the issue that multiple plugins have run into at startup. Blade did the same with BlRadar which ran into something on some systems as well, but we don't have a definitive root cause yet. More data will defiantly help convince Rich there is an issue here.
        • #19
          I just got back home from a business trip. Traced it back to a call to HS (GetIPAddress) for which ironically enough, Rich made a fix for me that went in post version .478 so I guess there is something wrong with it.
          Stay tuned.
          Dirk
          • #20
            Just received beta (.492) from Rich and problem seems resolved.
