Remotely reboot a SONOS device
    #31
    When I say play it manually I mean with the Sonos app. I can go try to recreate the database and see what happens. The song is spelled correctly (it hasn’t changed) so perhaps the dB did corrupt. When I get back to my computer I’ll do some testing...
      #32
      Ok, so this specific issue was resolved with a db rebuild - go figure, sometimes it’s the simplest things first. I guess with the other issue I’ve been having (not communicating with speaker) I fell into the trap of thinking this was part of the same thing, but most likely this was completely independent of it.
      if the speaker communication issues reoccur I’ll grab some debug and go from there...
      thanks again for your continued support!
      Paul
        #33
        Paul
        Just check which player you picked to make music databases, what time, then make sure that player is not off line or Hs was running non admin
          #34
          Finally got an opportunity to do some debug logging when one of my speakers wasn't responding again. debug log sent via PM. Here's the info:
          Scenario:
          Speaker: Zander's Room (IP and such in the PM.)
          Before I started logging, I found that I could no longer control the speaker from Homeseer, nor would HS pick up state changes from the speaker. I checked another speaker and found that the other speaker was still successfully being controlled, and reporting state change. So it's just the one speaker. All speakers are on SonosNet, back to a single speaker (Living Room) which is the only speaker currently connected to the network.
          During this time, the affected speaker can still be seen and controlled by Sonos Apps both on my phone, and via Sonos App directly installed on my Homeseer server for testing.
          After turning on the logging, I did:
          09:26:30 - Using the Sonos App, I changed the song to a song called Ocean Waves. This should have done two things:
          1. Should have reported the song change to HS
          2. Should have triggered an event that makes various changes to the playlist, volume, etc.
          Neither of the above happened.
          09:27:10 - Using Homeseer, I triggered an event that changes the playlist to a mediation plus Ocean Waves, and makes other changes to the volume, etc. The event ran, but there was no change to the speaker.
          Plugin version 3.1.0.28.
          Many thanks!
          Paul
            #35
            Scenario:
            Many thanks!
            Paul
            Do you recall the status of player Zander in the player table? If off-line, it won't do anything and clicking on anything just won't do anything because the PI lost the player, it is only when the player shows on-line and it is not doing anything that taking logs of clicking buttons might show something. Looking at the trace it is probably too short to find anything (11 minutes, should be 1h), there are no errors. Can you post a screen capture of the player table? I need to have the IP address and UDN for this player. There might be nothing at all in the log but at least I would know which entries to focus on.
            Dirk
              #36
              HI Dirk, Here's the Status Table. Zander's Room is showing as True, though I just tested it again and it's still not responding to Homeseer. Other speakers are stlil working.
              Player Name Player UDN Player OnLine Player Model Player IP Address Delete
              Harley's Room RINCON_B8E93787A7C401400 True S1 192.168.15.162 Delete
              Master Bedroom RINCON_000E58C94D6E01400 True S1 192.168.15.165 Delete
              Office RINCON_949F3E8D1C4A01400 True S12 192.168.15.168 Delete
              Living Room RINCON_5CAAFD95C1EA01400 True S1 192.168.15.164 Delete
              Zander's Room RINCON_949F3E1F962601400 True S12 192.168.15.167 Delete
              Fibre Room RINCON_000E58CF9D2C01400 True S1 192.168.15.161 Delete
              Kitchen RINCON_B8E9375B4FB201400 True S1 192.168.15.163 Delete
              Rec Room RINCON_000E58BB895101400 True S9 192.168.15.166 Delete
              If you still think a long hour plus log can help, let me know and I"ll make it happen....
              Paul
                #37
                Paul
                Is the system still in this state? You have not upgraded to the latest PI version, right?
                If still in this state, can you go to the player table and at the bottom it says "View Sonos Devices". Can you click on that and post the screenshot. I then need you to click on the hyperlinked (under device friendly name) for the "Zandar room" player. Now take again a screenshot and now look for the item "children=true". There should be two of them, one for the renderer and one for the server. Click on the links and again post screen shot result. These players are not paired with a playbar or playbase/playbeam are they?
                I think also player Fiber room is not working.
                  #38
                  Paul
                  Is the log in sync with the posted table? The log ONLY received unsolicited events from player with IP address 192.168.15.103 which doesn't even show in your table but with UDN = RINCON_000E58BB895101400 which in your table has IP address 192.168.15.166 ???? Did you restart your router or what's happening.
                  Nothing from the other players. Is this a Window machine? Firewall not configured properly?
                  I see from the trace that you used events as opposed to just clicking pause/stop etc on the device page. There are no events which explains why your events are not firing and perhaps there is something with the events as well.
                    #39
                    That's correct, still in this state, not upgraded yet - didn't want to muddy the waters. You're correct, the device is not paired with any other speakers. Ok, here's the View Sonos Devices:
                    UPnP Viewer
                    Device Friendly Name
                    Alive
                    IP Address
                    IP Port
                    Location
                    DeviceType
                    UDN
                    192.168.15.165 - Sonos Play:1 True 192.168.15.165 1400 http://192.168.15.165:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_000E58C94D6E01400
                    192.168.15.162 - Sonos Play:1 True 192.168.15.162 1400 http://192.168.15.162:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_B8E93787A7C401400
                    192.168.15.164 - Sonos Play:1 True 192.168.15.164 1400 http://192.168.15.164:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_5CAAFD95C1EA01400
                    192.168.15.166 - Sonos Playbar True 192.168.15.166 1400 http://192.168.15.166:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_000E58BB895101400
                    192.168.15.168 - Sonos Play:1 True 192.168.15.168 1400 http://192.168.15.168:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_949F3E8D1C4A01400
                    192.168.15.161 - Sonos Play:1 True 192.168.15.161 1400 http://192.168.15.161:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_000E58CF9D2C01400
                    192.168.15.163 - Sonos Play:1 True 192.168.15.163 1400 http://192.168.15.163:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_B8E9375B4FB201400
                    192.168.15.167 - Sonos Play:1 True 192.168.15.167 1400 http://192.168.15.167:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_949F3E1F962601400
                    192.168.15.160 - Sonos Bridge True 192.168.15.160 1400 http://192.168.15.160:1400/xml/device_description.xml urn:schemas-upnp-org:device:ZonePlayer:1 uuid:RINCON_000E58EEC6E401400
                    UPnP Device Viewer uuid:RINCON_949F3E1F962601400
                    Alive = True
                    Friendly Name = 192.168.15.167 - Sonos Play:1
                    Device UDN = uuid:RINCON_949F3E1F962601400
                    IP Address = 192.168.15.167
                    IP Port = 1400
                    Location = http://192.168.15.167:1400/xml/device_description.xml
                    Device Type = urn:schemas-upnp-org:device:ZonePlayer:1
                    Application URL =
                    WakeUp =
                    SSID =
                    Header = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:device:ZonePlayer:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:device:ZonePlayer:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Has Children = True
                    192.168.15.167 - Sonos Play:1 Media Server
                    Zander's Room - Sonos Play:1 Media Renderer
                    ManufacturerName = Sonos, Inc.
                    Model Number = S12
                    Has Services = 8
                    Service ID = urn:upnp-org:serviceId:AlarmClock
                    Service Type Identifier = urn:schemas-upnp-org:service:AlarmClock:1
                    Service LastTransportStatus = 0
                    Service Type = urn:schemas-upnp-org:service:AlarmClock:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:service:AlarmClock:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:service:AlarmClock:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/AlarmClock1.xml
                    Service Control URL = http://192.168.15.167:1400/AlarmClock/Control
                    Service Event URL = http://192.168.15.167:1400/AlarmClock/Event
                    Service ID = urn:upnp-org:serviceId:MusicServices
                    Service Type Identifier = urn:schemas-upnp-org:service:MusicServices:1
                    Service Type = urn:schemas-upnp-org:service:MusicServices:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:service:MusicServices:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:service:MusicServices:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/MusicServices1.xml
                    Service Control URL = http://192.168.15.167:1400/MusicServices/Control
                    Service Event URL = http://192.168.15.167:1400/MusicServices/Event
                    Service ID = urn:upnp-org:serviceIdeviceProperties
                    Service Type Identifier = urn:schemas-upnp-org:serviceeviceProperties:1
                    Service Type = urn:schemas-upnp-org:serviceeviceProperties:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:serviceeviceProperties:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:serviceeviceProperties:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/DeviceProperties1.xml
                    Service Control URL = http://192.168.15.167:1400/DeviceProperties/Control
                    Service Event URL = http://192.168.15.167:1400/DeviceProperties/Event
                    Service ID = urn:upnp-org:serviceId:SystemProperties
                    Service Type Identifier = urn:schemas-upnp-org:service:SystemProperties:1
                    Service Type = urn:schemas-upnp-org:service:SystemProperties:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:service:SystemProperties:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:service:SystemProperties:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/SystemProperties1.xml
                    Service Control URL = http://192.168.15.167:1400/SystemProperties/Control
                    Service Event URL = http://192.168.15.167:1400/SystemProperties/Event
                    Service ID = urn:upnp-org:serviceId:ZoneGroupTopology
                    Service Type Identifier = urn:schemas-upnp-org:service:ZoneGroupTopology:1
                    Service Type = urn:schemas-upnp-org:service:ZoneGroupTopology:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:service:ZoneGroupTopology:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:service:ZoneGroupTopology:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/ZoneGroupTopology1.xml
                    Service Control URL = http://192.168.15.167:1400/ZoneGroupTopology/Control
                    Service Event URL = http://192.168.15.167:1400/ZoneGroupTopology/Event
                    Service ID = urn:upnp-org:serviceId:GroupManagement
                    Service Type Identifier = urn:schemas-upnp-org:service:GroupManagement:1
                    Service Type = urn:schemas-upnp-org:service:GroupManagement:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:service:GroupManagement:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-upnp-org:service:GroupManagement:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/GroupManagement1.xml
                    Service Control URL = http://192.168.15.167:1400/GroupManagement/Control
                    Service Event URL = http://192.168.15.167:1400/GroupManagement/Event
                    Service ID = urn:tencent-com:serviceId:QPlay
                    Service Type Identifier = urn:schemas-tencent-com:service:QPlay:1
                    Service Type = urn:schemas-tencent-com:service:QPlay:1
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-tencent-com:service:QPlay:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:schemas-tencent-com:service:QPlay:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Service URL = http://192.168.15.167:1400/xml/QPlay1.xml
                    Service Control URL = http://192.168.15.167:1400/QPlay/Control
                    Service Event URL = http://192.168.15.167:1400/QPlay/Event
                    Service ID = urn:smartspeaker-audio:service:SpeakerGroup:1
                    Service Type Identifier = urn:smartspeaker-audio:service:SpeakerGroup:1
                    Service Type = urn:smartspeaker-audio:service:SpeakerGroup:1
                    Location = http://192.168.15.167:1400/xml/group_description.xml
                    NotificationEvent = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 3600 LOCATION: http://192.168.15.167:1400/xml/group_description.xml NT: urn:smartspeaker-audio:service:SpeakerGroup:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400::urn:smartspeaker-audio:service:SpeakerGroup:1 BOOTID.UPNP.ORG: 76 CONFIGID.UPNP.ORG: 10 GROUPINFO.SMARTSPEAKER.AUDIO: gc=1; gid=RINCON_B8E93787A7C401400:467; gname="Zander's Room" WEBSOCK.SMARTSPEAKER.AUDIO: wss://192.168.15.167:1443/websocket/api HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP APIVER.SMARTSPEAKER.AUDIO: 1.15.1 MINAPIVER.SMARTSPEAKER.AUDIO: 1.1.0 receiveep:192.168.15.167:47083
                    Service URL =
                    Service Event URL =
                    UPnP Device Viewer uuid:RINCON_949F3E1F962601400_MS
                    Alive = True
                    Friendly Name = 192.168.15.167 - Sonos Play:1 Media Server
                    Device UDN = uuid:RINCON_949F3E1F962601400_MS
                    IP Port = 1400
                    Device Type = urn:schemas-upnp-org:device:MediaServer:1
                    Application URL =
                    WakeUp =
                    SSID =
                    Header = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:device:MediaServer:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400_MS::urn:schemas-upnp-org:device:MediaServer:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Has Children = False
                    Model Number = S12
                    Has Services = 2
                    Service ID = urn:upnp-org:serviceId:ContentDirectory
                    Service Type Identifier = urn:schemas-upnp-org:service:ContentDirectory:1
                    Service Type = urn:schemas-upnp-org:service:ContentDirectory:1
                    Service URL = http://192.168.15.167:1400/xml/ContentDirectory1.xml
                    Service Control URL = http://192.168.15.167:1400/MediaServ...ectory/Control
                    Service Event URL = http://192.168.15.167:1400/MediaServ...irectory/Event
                    Service ID = urn:upnp-org:serviceId:ConnectionManager
                    Service Type Identifier = urn:schemas-upnp-org:service:ConnectionManager:1
                    Service Type = urn:schemas-upnp-org:service:ConnectionManager:1
                    Service URL = http://192.168.15.167:1400/xml/ConnectionManager1.xml
                    Service Control URL = http://192.168.15.167:1400/MediaServ...anager/Control
                    Service Event URL = http://192.168.15.167:1400/MediaServ...nManager/Event
                    UPnP Device Viewer uuid:RINCON_949F3E1F962601400_MR
                    Alive = True
                    Friendly Name = Zander's Room - Sonos Play:1 Media Renderer
                    Device UDN = uuid:RINCON_949F3E1F962601400_MR
                    IP Port = 1400
                    Device Type = urn:schemas-upnp-org:device:MediaRenderer:1
                    Application URL =
                    WakeUp =
                    SSID =
                    Header = NOTIFY * HTTP/1.1 HOST: 239.255.255.250:1900 CACHE-CONTROL: max-age = 1800 LOCATION: http://192.168.15.167:1400/xml/device_description.xml NT: urn:schemas-upnp-org:device:MediaRenderer:1 NTS: ssdp:alive SERVER: Linux UPnP/1.0 Sonos/53.2-70100 (ZPS12) USN: uuid:RINCON_949F3E1F962601400_MR::urn:schemas-upnp-org:device:MediaRenderer:1 X-RINCON-HOUSEHOLD: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF X-RINCON-BOOTSEQ: 76 X-RINCON-WIFIMODE: 0 X-RINCON-VARIANT: 2 HOUSEHOLD.SMARTSPEAKER.AUDIO: Sonos_2GCppHTdSXNVM9QGJQjffnVGUF.1NohWHaQSiTHB8CfmkPP receiveep:192.168.15.167:37244
                    Model Number = S12
                    Has Services = 6
                    Service ID = urn:upnp-org:serviceId:RenderingControl
                    Service Type Identifier = urn:schemas-upnp-org:service:RenderingControl:1
                    Service Type = urn:schemas-upnp-org:service:RenderingControl:1
                    Service URL = http://192.168.15.167:1400/xml/RenderingControl1.xml
                    Service Control URL = http://192.168.15.167:1400/MediaRend...ontrol/Control
                    Service Event URL = http://192.168.15.167:1400/MediaRend...gControl/Event
                    Service Control URL = http://192.168.15.167:1400/MediaRend...anager/Control
                    Service Event URL = http://192.168.15.167:1400/MediaRend...nManager/Event
                    Service ID = urn:upnp-org:serviceId:AVTransport
                    Service Type Identifier = urn:schemas-upnp-org:service:AVTransport:1
                    Service Type = urn:schemas-upnp-org:service:AVTransport:1
                    Service URL = http://192.168.15.167:1400/xml/AVTransport1.xml
                    Service Control URL = http://192.168.15.167:1400/MediaRend...nsport/Control
                    Service Event URL = http://192.168.15.167:1400/MediaRend...ransport/Event
                    Service ID = urn:sonos-com:serviceId:Queue
                    Service Type Identifier = urn:schemas-sonos-com:service:Queue:1
                    Service Type = urn:schemas-sonos-com:service:Queue:1
                    Service URL = http://192.168.15.167:1400/xml/Queue1.xml
                    Service Control URL = http://192.168.15.167:1400/MediaRenderer/Queue/Control
                    Service Event URL = http://192.168.15.167:1400/MediaRenderer/Queue/Event
                    Service ID = urn:upnp-org:serviceId:GroupRenderingControl
                    Service Type Identifier = urn:schemas-upnp-org:service:GroupRenderingControl:1
                    Service Type = urn:schemas-upnp-org:service:GroupRenderingControl:1
                    Service URL = http://192.168.15.167:1400/xml/Group...ngControl1.xml
                    Service ID = urn:upnp-org:serviceId:VirtualLineIn
                    Service Type Identifier = urn:schemas-upnp-org:service:VirtualLineIn:1
                    Service Type = urn:schemas-upnp-org:service:VirtualLineIn:1
                    Service URL = http://192.168.15.167:1400/xml/VirtualLineIn1.xml
                    Service Control URL = http://192.168.15.167:1400/MediaRend...LineIn/Control
                    Service Event URL = http://192.168.15.167:1400/MediaRend...alLineIn/Event
                    Many thanks!
                    Paul
                      #40
                      Hey Dirk,
                      The log is accurate, and yeah the posted table hasn't changed - all IPs are static, no changes anywhere. 192.168.15.103 is the IP of my homeseer server. I haven't restarted anything today. I'm not sure I understand what yo mean by "There are no events which explains why your events are not firing..." I have an event that listens for the specific playlist change mentioned earlier, and the event that I used to trigger the change on the speaker (that isn't successfully hitting the speaker) is what I fired.
                      Both these events are pretty straightforward, I can post them if you'd like to see them, but I"m (fairly) confident that they're solid. They worked flawlessly 100% of the time for several years before this issue started with speakers occasionally stopping working from homeseer. What I can tell you is that right now the speaker in question probably won't work until I bounce the speaker (which is good from a longevity of troubleshooting perspectiive). I'm about to hit the sack, but if you like tomorrow I could do some more debugging, charting out again the failure for that speaker, leave the logs alone for an hour, then I could pull the plug on teh speaker and plug it back in, which will most likely then allow communication to the speaker again. Might make for an interesting log?
                      regards,
                      Paul
                        #41
                        Hey Dirk,
                        regards,
                        Paul
                        Looking through the log, I find the event where you try to play a track. However, the absence of some expected log entries suggest that either the PI thinks the player is off-line or the service is not existing. The player table unfortunately shows the UPNP subsystem view where the player appear to be happy. There is an audit in the PI to detect inconsistencies but that does seem to rectify it which leaves the last possibility that we lost the service somehow, and I'm not sure how I can debunk that theory or confirm it, or how that even could have happened.
                        So before we decide to upgrade and potentially wipe out all evidence, you could leave the log on for 1 hour, during that hour, say in the first few minutes, do some actions from the SONOS APP(!!) to say pause/play or change track on the Zander player, I want to check that at least events show up. At the end of the hour, we could try to reboot the Zander player and see if that makes a difference. If it doesn't make a difference, you could take the Zander player off-line for 1 hour and reconnect it, that I would think will take care of this issue. If you take the zander player off-line, you can monitor the player table and once it goes off-line, you can reconnect it. The close the log and zip it and tell me at which times you did what.
                        Dirk
                          #42
                          Sounds good, I'll make that happen. At work right now, as soon as I get home I'll set it up.
                          Indeed I agree that unplugging the speaker will likely fix it, that's typically what works for me. Just annoying that it happens, since the problem will reoccur again a few days from now if I do that.
                          Cool, when I get home I'll do the following. Let me know if I should adjust this list:
                          - Setup debug logging
                          - play, pause, play, change a track on Zander
                          - play, pause, play using direct control in HS3
                          - run my event that changes the playlist, repeat and volume in HS3
                          - Leave debug running for an hour
                          - unplug Zander
                          - monitor player table until Zander shows Off-Line
                          - plug back in
                          - Monitor player table until Zander shows On-line
                          - Re-test connectivity as above
                          - shut down debug log
                          - document exactly what times each step was performed
                          Thanks!
                          Paul
                            #43
                            - unplug Zander
                            - plug back in
                            Thanks!
                            Paul
                            Sounds about right.
                            If unplugging Zander fixes it, what we could do is leave things as is, set regular debug on, NO super debug and upnp log level to errors only, log to disk and hope it happens soon again. What I at least would expect is some events from Zander dropping out and somehow messing up state between upnp and plug in. Would be great to find out and perhaps add some audit functions to catch and correct those. There is a chance that the latest version takes care of business but this issue seems a bit different from what I’ve seen before
                              #44
                              Sounds good. I'll do the above, and if unplugging does fix it at the end, after copying out the log I'll turn regular debug on as directed and let it go.....
                                #45
                                Do you normally leave any debit log on for this PI? I need to look at code but it could be that players dropping out leave log entries. If you go to the HS log page and open up options, search on things like warning or error or Zander or the up address of Zander or the udn of Zander, does anything show up of interest?
