What causes the timeout error?
  • What causes the timeout error?
    May-23 5:58:42 PM Sonos Error Error in DoCheckAnnouncementQueue. 100 seconds expired since the announcement started and no end was received.
    May-23 5:58:41 PM Sonos Error Error in DoCheckAnnouncementQueue. 100 seconds expired since the announcement started and no end was received.
    Michael
    HS3 Pro 3.0.0.470 | 849 devices | 349 events | OpenSprinkler | BLShutdown | EasyTrigger | NetCAM | Harmony Hub | Sonos | SDJ-Health | BLUPS | PHLocation | BLBackup | BLLock | Z-Wave 3.0.1.243 | weatherXML | Pushover 3P | Blue-Iris | AirPlaySpeak
    I upgraded the Sonos PI from .28 to .30 and began getting these errors - no other changes were made.
    Reverted to .28 and still getting them so am reaching out for other explanations.
    Michael
      Have you tried to restart HS? When the text is converted to a speech file, it is written in a section where HS lives but which is a subdirectory of "Program Files (x86)" (assuming this is on Windows) therefore the PI needs to have admin rights to write there, else you will have this kind of error. So check the <hs root>\html\Sonos\Announcements subdirectory. If the PI can't write there (seen this with admin rights or locked file that can't be overwritten), delete the files in the subdir and check after the announcement that a file showed up.
        Restarted a couple of times, was getting the error. Then a few hours later, no errors and working fine.
        Michael
