Hi,
I'm seeing this when HS starts up.
Warning in InitIO for Instance = received (192.168.0.5), which is a different IP adress from it's server binding ()
I thought it was because I deleted some zones and rebooted but believe this is a red herring.
As an aside, I had to delete the .ini file and restart HS for these zones to reappear, however I still get the same error above.
I've had a search around and came across this post but that's not really helped me.
I'm running Windows 10 64bit, HS3 Pro Edition 3.0.0.425 on a physical server purely dedicated to HS.
Grateful for some advice. Thanks
