Error in Adding VirtualLineIn Call Back for zoneplayer
  • Error in Adding VirtualLineIn Call Back for zoneplayer
    I am running
    HomeSeer Version: HS3 Pro Edition 3.0.0.534
    Operating System: Microsoft Windows 10 Enterprise 2016 LTSB - Work Station
    3.1.0.30: Sonos
    I am seeing the this error in the logs:
    2019-07-13 14:18:29 Sonos Error Error in Adding VirtualLineIn Call Back for zoneplayer = Master Bedroom. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.x.x9:1400/MediaRender...alLineIn/Event to = http://192.168.7.39:1400/MediaRender...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable.
    2019-07-13 14:18:29 Sonos Error Error in MyUPnPService.AddCallback while sending URL = http://192.168.X.X9:1400/MediaRender...alLineIn/Event to = http://192.168.x.x9:1400/MediaRender...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable.
    2019-07-13 14:18:28 Starting Plug-In Plugin Sonos started successfully in 8 milliseconds
    2019-07-13 14:18:28 Starting Plug-In Initializing plugin Sonos ...
    2019-07-13 14:18:28 Info Plugin Sonos with instance RINCON_B8E9375F64BA01400 has connected. IP:127.0.0.1:50969
    2019-07-13 14:18:26 Starting Plug-In Plugin Sonos started successfully in 12 milliseconds
    2019-07-13 14:18:26 Starting Plug-In Initializing plugin Sonos ...
    2019-07-13 14:18:26 Info Plugin Sonos with instance RINCON_7828CA10103A01400 has connected. IP:127.0.0.1:50944
    2019-07-13 14:18:24 Starting Plug-In Plugin Sonos started successfully in 8 milliseconds
    2019-07-13 14:18:24 Starting Plug-In Initializing plugin Sonos ...
    2019-07-13 14:18:24 Info Plugin Sonos with instance RINCON_5CAAFD080B4801400 has connected. IP:127.0.0.1:50913
    2019-07-13 14:18:23 Sonos Error Error in Adding VirtualLineIn Call Back for zoneplayer = Bathroom 2. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.x.x0:1400/MediaRender...alLineIn/Event to = http://192.168.7.40:1400/MediaRender...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable.
    2019-07-13 14:18:23 Sonos Error Error in MyUPnPService.AddCallback while sending URL = http://192.168.X.X0:1400/MediaRender...alLineIn/Event to = http://192.168.x.x0:1400/MediaRender...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable.
    2019-07-13 14:18:22 Starting Plug-In Plugin Sonos started successfully in 7 milliseconds
    2019-07-13 14:18:22 Starting Plug-In Initializing plugin Sonos ...
    2019-07-13 14:18:22 Info Plugin Sonos with instance RINCON_B8E9375D2D4A01400 has connected. IP:127.0.0.1:50886
    This is after restarting Homeseer - I saw this before restarting as well
    Jul-13 14:35:17 Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\PlayerControl:RINCON_B8E9375F64BA01400
    _B8E9375F64BA01400
    This is the Master Bedroom which is throwing the error above
    The .x9 = Play:1
    The .x0 = Play:1
    I have a Play:5 and a SONOS One here as well
    I am using a boost as i prefer it to wireless
    My Hometroller is running wirelessly however I also get the errors during a wired session
    Originally posted by harvito View Post
    I am running
    3.1.0.30: Sonos
    _B8E9375F64BA01400
    The .x9 = Play:1
    The .x0 = Play:1
    Is anything not working?
      Well - it appears I lost all the favorites, radio stations and the virtuallinein fails on two speakers - I have now uninstalled the PL - I did so using the steps you gave someone else in this forum - I have now reinstalled - I do not see the errors but I am now waiting on the favorites and radio stations to update. I'll let you know what happens.
        The virtualLineIn has no function, I coded it at some point, thinking I might use it, I believe it has something to do with controlling devices connected via HDMI. The fact that you did get an error on it is interesting. Can you post a screenshot of your player table and list which players are paired.
        The favorites and radiostations, unless you have set it to automatic (in the PI config screen), you need to do it manually. I don't recommend to set it to immediate as nowadays too many things are stored in the Sonos DB and the PI could get quite busy continuously transferring the DB. So my recommendation is to set it automatic, which means daily and set it to say 2:05am. If you did update something on Sonos and you want it urgently on the PI, then just do it manually (click on control for the master device and then click buildDB). One thing you may want to check in the config settings, which player is selected as the DB Zone Name? Make sure this isn't a paired S1 or something that is providing surround sound for a Play bar/beam/base.
        Dirk
          So - I turned on debug and watched the logs - seems okay - I was worried the favorites and radio stations were failing as I set the update to 21:30 but I did not see it update in the logs - I than turned on the 'auto update flag' and within a few minutes the update started and finished. So, it appears for now to be good. I never like pulling out the sledge hammer but this time it was the last resort - so let's see if it all stays -
          So, I do have an off topic question - How do you utilize the speakers for announcements - like 'Welcome home sir.'
            Didn’t see your update - I’ll get the screen shoot to you tomorrow- just closed the lid on the MacBook - time to veg and watch a movie.
            Just wanted to add - I appreciate how quickly you reply -
              Click on Tools (top of the HS management screen), Click Help, Click Sonos .... read :-)
                Uploaded new version .34 in the beta section of the installer. This version should "fix" the errors
                  cool - just do the update or do I need to follow a particular process.
                    just do the install , remember from the beta section!
                      Note: I am finding info on the VirtualLinein call - It seems it is used for Airplay
