Hi,
Have sometimes noticed that there is a error in the log from the Sonos plugin.
Have not noticed any trouble regarding usage.
When I restart the plugin I get these errors:
But after letting the plugin settle for a while, I can't seem to notice any impact on the usage.
Without any deep testing, the speakers are working as it should in our daily lives.
Any thoughts?
okt-27 23:20:30 | Sonos | Registered SpeakerProxy |
okt-27 23:20:30 | Sonos | CreateOneSonosController: Created instance of ZonePlayerController for Zoneplayer = Eine with index 6 |
okt-27 23:20:30 | Sonos Error | Error in Adding VirtualLineIn Call Back for zoneplayer = Eine. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.10.187:1400/MediaRend...alLineIn/Event to = http://192.168.10.187:1400/MediaRend...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable. |
okt-27 23:20:30 | Sonos | DirectConnect called for Zone Eine with device name = uuid:RINCON_B8E937B6FAB601400 and Model = S1 |
okt-27 23:20:29 | Starting Plug-In | Plugin Sonos started successfully in 8 milliseconds |
okt-27 23:20:29 | Sonos | InitIO Called for Instance = RINCON_B8E937B6FAB601400 and running on OS = Win32NT |
okt-27 23:20:29 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:20:29 | Info | Plugin Sonos with instance RINCON_B8E937B6FAB601400 has connected. IP:127.0.0.1:60173 |
okt-27 23:20:29 | Sonos | CreateOneSonosController: Created instance of ZonePlayerController for Zoneplayer = Bad with index 5 |
okt-27 23:20:29 | Sonos Error | Error in Adding VirtualLineIn Call Back for zoneplayer = Bad. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.10.186:1400/MediaRend...alLineIn/Event to = http://192.168.10.186:1400/MediaRend...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable. |
okt-27 23:20:28 | Sonos | DirectConnect called for Zone Bad with device name = uuid:RINCON_B8E937864BD801400 and Model = S1 |
okt-27 23:20:27 | Starting Plug-In | Plugin Sonos started successfully in 8 milliseconds |
okt-27 23:20:27 | Sonos | InitIO Called for Instance = RINCON_B8E937864BD801400 and running on OS = Win32NT |
okt-27 23:20:27 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:20:27 | Info | Plugin Sonos with instance RINCON_B8E937864BD801400 has connected. IP:127.0.0.1:60144 |
okt-27 23:20:27 | Sonos | CreateOneSonosController: Created instance of ZonePlayerController for Zoneplayer = Kjøkken with index 4 |
okt-27 23:20:27 | Sonos Error | Error in Adding VirtualLineIn Call Back for zoneplayer = Kjøkken. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.10.111:1400/MediaRend...alLineIn/Event to = http://192.168.10.111:1400/MediaRend...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable. |
okt-27 23:20:27 | Sonos | DirectConnect called for Zone Kjøkken with device name = uuid:RINCON_B8E9378EA8E601400 and Model = S1 |
okt-27 23:20:26 | Starting Plug-In | Plugin Sonos started successfully in 10 milliseconds |
okt-27 23:20:26 | Sonos | InitIO Called for Instance = RINCON_B8E9378EA8E601400 and running on OS = Win32NT |
okt-27 23:20:26 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:20:26 | Info | Plugin Sonos with instance RINCON_B8E9378EA8E601400 has connected. IP:127.0.0.1:60114 |
okt-27 23:20:26 | Sonos | CreateOneSonosController: Created instance of ZonePlayerController for Zoneplayer = Ingvild with index 3 |
okt-27 23:20:26 | Sonos Error | Error in Adding VirtualLineIn Call Back for zoneplayer = Ingvild. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.10.228:1400/MediaRend...alLineIn/Event to = http://192.168.10.228:1400/MediaRend...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable. |
okt-27 23:20:26 | Sonos | DirectConnect called for Zone Ingvild with device name = uuid:RINCON_B8E937B7044C01400 and Model = S1 |
okt-27 23:20:25 | Starting Plug-In | Plugin Sonos started successfully in 8 milliseconds |
okt-27 23:20:25 | Sonos | InitIO Called for Instance = RINCON_B8E937B7044C01400 and running on OS = Win32NT |
okt-27 23:20:25 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:20:25 | Info | Plugin Sonos with instance RINCON_B8E937B7044C01400 has connected. IP:127.0.0.1:60087 |
okt-27 23:20:25 | Sonos | CreateOneSonosController: Created instance of ZonePlayerController for Zoneplayer = Playbar with index 2 |
okt-27 23:20:25 | Sonos Error | Error in Adding VirtualLineIn Call Back for zoneplayer = Playbar. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.10.171:1400/MediaRend...alLineIn/Event to = http://192.168.10.171:1400/MediaRend...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable. |
okt-27 23:20:24 | Sonos | DirectConnect called for Zone Playbar with device name = uuid:RINCON_5CAAFD16BDDE01400 and Model = S9 |
okt-27 23:20:24 | Starting Plug-In | Plugin Sonos started successfully in 7 milliseconds |
okt-27 23:20:24 | Sonos | InitIO Called for Instance = RINCON_5CAAFD16BDDE01400 and running on OS = Win32NT |
okt-27 23:20:24 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:20:23 | Info | Plugin Sonos with instance RINCON_5CAAFD16BDDE01400 has connected. IP:127.0.0.1:60059 |
okt-27 23:20:23 | Sonos | CreateOneSonosController: Created instance of ZonePlayerController for Zoneplayer = Loftstue with index 1 |
okt-27 23:20:23 | Sonos Error | Error in Adding VirtualLineIn Call Back for zoneplayer = Loftstue. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.10.147:1400/MediaRend...alLineIn/Event to = http://192.168.10.147:1400/MediaRend...alLineIn/Event with error = The remote server returned an error: (503) Server Unavailable. |
okt-27 23:20:23 | Sonos | DirectConnect called for Zone Loftstue with device name = uuid:RINCON_5CAAFD4557A001400 and Model = S1 |
okt-27 23:20:22 | Starting Plug-In | Plugin Sonos started successfully in 11 milliseconds |
okt-27 23:20:22 | Sonos | InitIO Called for Instance = RINCON_5CAAFD4557A001400 and running on OS = Win32NT |
okt-27 23:20:22 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:20:22 | Info | Plugin Sonos with instance RINCON_5CAAFD4557A001400 has connected. IP:127.0.0.1:60032 |
okt-27 23:19:41 | Plug-In | Finished initializing plug-in Sonos |
okt-27 23:19:41 | Starting Plug-In | Sonos loaded in 605 milliseconds |
okt-27 23:19:41 | Starting Plug-In | Plugin Sonos started successfully in 215 milliseconds |
okt-27 23:19:41 | Sonos | Sonos Plugin Initialized |
okt-27 23:19:40 | Sonos | InitIO Called for Instance = |
okt-27 23:19:40 | Sonos | InitIO for Instance = found this plugin running on Linux = False |
okt-27 23:19:40 | Sonos | InitIO Called for Instance = and running on OS = Win32NT |
okt-27 23:19:40 | Sonos | InitIO for Instance = found HS running on Linux = False |
okt-27 23:19:40 | Sonos | InitIO for Instance = found CurrentAppPath = C:\Program Files (x86)\HomeSeer HS3 |
okt-27 23:19:40 | Starting Plug-In | Initializing plugin Sonos ... |
okt-27 23:19:40 | Info | Plugin Sonos has connected. IP:127.0.0.1:59923 |
Any thoughts?
