Error can u advise thank you - Solved!
    9/6/2011 7:15:32 PM SONOSCONTROLLER Error in ActionUIFormat: Index was outside the bounds of the array.
    9/6/2011 7:15:26 PM SONOSCONTROLLER Error in ActionUIFormat: Index was outside the bounds of the array.
    No sorry thought i got it still getting this error when running tts sounds is working great but error in log
    Hi Wingo,
    did you by any chance upgraded from an older version of the plugin and had these events created in a version like v.048 or older? In that case, I suggest you delete and recreate the event.
    I think you actually get this error when you open the event page in HS, is that correct? In that case it would indicate one of the events associated with the Sonos plugin has an issue. If you see no issue, just open the actions/events and save them again, see if that takes care of the problem.
    Which plug-in version are you running?
    If you spot no issue, send me a personal email with the sonoscontroller.ini file and some screen shots on your events/actions so I can have a look at it.
    Dirk
      Thank U very much it was a event that needed to be deleted......
      Great plugin.......
      Robert
