Set volume level with script
    Hi,
    I would like to set the volume level for a sonos zone to a specific value using script. ie set zone xx to volume level 50. I can do it using an event, but I need to script it so I can pass a value from Hstouch.
    Is this possible?
    Cheers,
    Rob
    P.S It's looking good since i last used your test version a year ago!
    Hi Rob,
    check the help file at the end for all the API information. Your script would look something like this:
    Public Sub SetYourVolume (ZoneNameOrIndex As String, NewVolume As Integer)
    Dim pi As Object
    pi = hs.Plugin("SONOSCONTROLLER")
    If pi Is Nothing Then
    hs.writelog("Script", "empty")
    Exit Function
    End If
    Dim MusicAPI
    MusicAPI = pi.GetMusicAPI(ZoneNameOrIndex)
    MusicAPI.Volume(NewVolume)
    End Sub
    Let me know if you have other questions
    Dirk
      Thanks Dirk,
      I didn't realise .Volume was able to set the value. I thought it just returned it. Doh!
      Rob
        Indeed help file not clear on this. Updated help file, will be released together with next beta.
        Dirk
          Dirk, how would you call the above in HS touch? I think I'm doing something wrong. I assumed it was the following but I suppose not?
          &hs.runex("NameOfVBscripthere.vb","NameofSubHere","ZoneName","VolumeLevel")
          Thanks!
          Edit: regardless of the way it's called I get an error in the End Function routine stating that this is the wrong place for it? It works (well, I still can't pass it the right parameters) if I remove the 'End Function' in that if loop.
            Thanks!
            Not sure I'm following on your remark about "End Function"? Can you post the script here as well. Seem to remember there is a limitation on the # of parameters you pass into a script. If you are over the limit of parameters, pass then as a string separated by lets say "|" characters and do a split inside the script.
            I'm this week on the road so I have no access to pretty much anything.
            Dirk
              The script is one that you posted a couple of posts up.
              I tried to change it to a (ByVar parms) and split the parms. I then used "Zonename;VolumeLevel" in my runex but that failed too.
              Ahh well, I'll keep tinkering
              Thanks!
                EDIT: I get the following error with the second script. it's a long string that includes "Parameter count mismatch"..
                I get the following error in my script "Overload resolution failed because no accessible 'Volume' accepts this number of arguments."
                Here's my attempt with splitting the parms but I can't get it to work either. Called with:
                &hs.runex("NameOfVBscripthere.vb","SetVolume","ZoneName;50")
                Public Sub SetVolume(ByVal parm)
                	Dim pi As Object
                		hs.writelog("Script","empty")
                	End If
                	Dim Parms() = {}
                	Dim ZoneName, NewVolume
                	Try
                        Parms = Split(Parm, ";")
                    Catch ex As Exception
                        hs.writelog("Sonos Controller Script", "1 - Error in SetVolume with error = " & Ex.Message)
                        Exit Sub
                    End Try
                	Dim MusicAPI
                	ZoneName = Parms(0)
                	NewVolume = Parms(1)
                Try
                	MusicAPI = pi.GetMusicAPI(ZoneName)
                        hs.writelog("Sonos Controller Script", "2 - Error in SetVolume with error = " & Ex.Message)
                        Exit Sub
                    End Try
                End Sub
                The script that you posted was much simpler and I'd like to use it. Called with:
                &hs.runex("NameOfVBscripthere.vb","SetVolume","ZoneName","50")
                Public Sub SetVolume (ZoneNameOrIndex As String, NewVolume As Integer)
                Dim pi As Object
                Exit Function
                End If
                Dim MusicAPI
                End Sub
                      Dim pi As Object
                      End If
                      Dim Parms() = {}
                      Try
                          Exit Sub
                      End Try
                      Dim MusicAPI
                      ZoneName = Parms(0)
                  Try
                          Exit Sub
                      End Try
                  End Sub
                  Dim pi As Object
                  Exit Function
                  End If
                  Dim MusicAPI
                  End Sub
                  Declare the newVolume variable as an Integer and convert input parm from string to integer.
                  If that still doesn't work, check the help file for correct syntax. As I wrote in the older post .... "would look something like this"
                  Dirk
                    Thanks Dirk but unfortunately I'm met with the same error:
                    SetVolume with error = Overload resolution failed because no accessible 'Volume' accepts this number of arguments.
                    The help file merely states the below in the MusicAPI sub-heading:
                    Public Property Volume As Integer ’Set/Returns the current volume setting of the player from 0 to 100.
                    I have no idea what the hell I'm doing wrong
                    EDIT, I wrote the parms to the log just to see their values after the changes and I'm getting a proper Integer (20) for 'NewVolume' and a proper Zonename for 'ZoneName'..
                      when everything else fails .... put in some debug log statements. Print out variables zonename and newvolume, are they what you think they are?
                      If you read the volume in your script, does that work?
                      Dirk
                        Haha, got it by reading the Homeseer SDK.. Volume is not "Volume(parm)" it's "Volume = parm"
                        Thanks for your help Dirk!
                          oops ..... had my disclaimer it was "something like that" . Hate it when code is so strict
                          Dirk
                            Yeah, you're fired...
