Not exactly related to the Sonos plug-in but I thought it would be a good place to ask.
I have been pondering what to do about whole house audio and HS for some time and my main requirement is to get HS speech integrated.
Currently my HA gear is distributed around the house and my HS PC is connected to a set of good quality wired speakers located centrally in the house and this is used soley for HS speech. I have recently created a new office / study and I intend to move all my HA gear into a purpose built cabinet in that room so I can simplify the installation. This means that my HS PC will be moved from it's current central location into the cabinet.
I could use a long audio cable from the HS PC and leave the speakers where they are but I thought it would be an opportune time to get whole house audio working.
So onto my question. I have searched various Sonos info but I was unable to clarify what I need.
I understand that the best way to integrate HS speech into Sonos is to use the line in method and use the line out of the HS PC. If this is the case then can a Sonos Connect (ZP90) be used in my HA cabinet as a line in for HS and also act as a bridge?
I know I can use a Play5 as a line in / bridge but as the HS PC is inside a cabinet and I have nowhere to mount the Play5 outise the cabinet, it seems a bit of a waste.
So what I am asking is: can I use a Connect (ZP90) and 2 Play5's to create a working system?
Thanks in advance.
Paul..
Thanks in advance.
Paul..
