New to Sonos, so forgive my cluelessness. I have read all the TTS threads, but I am still confused.
My plan is to slowly wean myself off the Media Player plugin in favor of Sonos - only one whole-house zone for now. So I want both MP and Sonos systems to be active while I work on integrating Sonos into my interfaces, scripts, etc. I use an AB8SS speaker switcher (2 inputs, 8 outputs) - input A is HS with Media Player, input B will be HS with Sonos. I have split the line-out from HS - one to my existing A side amp (for MP), and one to the Connect and its B side amp (for Sonos). Most of my TTS announcements are via script. So when MP is running, I use HS's normal TTS interruption. When Sonos is running, I should have the same HS TTS coming into the Connect via its line in. So my thought is that I should get my announcements using either system.
I have been trying a few simple events to try out TTS, but getting unexpected results. I must be doing something wrong, and/or I just don't understand how it works.
Problem 1: If I send TTS out of the HS default line out, I hear it on A and B sides - makes sense. If I do speakex 60 or route to $SONOS$TTS$AUDREY3EFAULT, I still hear it on A. Shouldn't that send directly to the Connect and not via HS line out?
Problem 2: If I send TTS while Sonos is playing a tune, the music stops, switches to Sonos line-in and I catch only the last few seconds of speech. I guess I can add a delay for that. But music does not resume after the speech. I have to restart music manually to switch back. Also, when I do restart music, the Sonos volume is turned way down. Is that the way it is supposed to work, or have I messed up? I assumed that the PI would pause music and restart when TTS was done.
Screenshots attached for Config and test events.
Sorry for the long story. Please help the clueless.
