Hi Dirk
I moved away from TTS events as I noticed them to be a little slow instead I use a line-in to one of my Connect Amps from my HS Server.
I then have an event group for each speaker and copy a main speak event which is EAGLE54-HAEFAULT
I can then easily setup speech events per speaker by coping this event.
Depending on the speaker - the group actions change ie the group actions for the living room come under the event group for the living room speakers.
The problem is that occasional one or two speakers seem to freeze, i.e you cant select anything to play from the playlist, then you get red lines through the device. Two screens taken whilst this fault has occurred on the bathroom speaker and i am unable to play event, or do anything with the speaker. The only solution I have found which seems to recover it - is restarting the whole sonos plugin.
It also seems random on how many or which speakers and I haven't been able to associate an event or common cause?
Have you any thoughts on what may be wrong?
I'm not even sure if I am causing this by these events - bathroom has three events for speech, an end event and group actions and nothing more.
Have you come across faults like below where you get the red lines through the mute, repeat, shuffle and no matter what you press or select add to playlist - it does not respond? Even if I play something through the actual SONOS app, although that works - the bathroom speaker still is unresponsive?
Thanks Chris
Thanks Chris
