(Almost) the same error here:
ERROR in SetTransportState for zoneplayer = Living Room 2 with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://10.0.0.147:1400/xml/AVTransport1.xml while sending Action = Play for URI = http://10.0.0.147:1400/MediaRenderer...nsport/Control and Request = 0 1 UPNP Error = faultcode = s:Client, faultstring = UPnPError, detail = 701 with error = The remote server returned an error: (500) Internal Server Error."
This happens when I use " play url" to start a DI.FM premium stream (I do have a subscription to this, manually configured radiostation in Sonos app using url works perfect).
Running Sonos Play1 (2x), Play 3 (2x), sub and player. Play3, sub and player are linked as "living room". Playbar connected via ethernet, all other players using Sonos Boost.
Other problems:
Trying to play using Homeseer command "control a device" and then choose play works fine, but no control over what is played (cannot choose playlist, track, url or anything else, seems to use previously used playlist)
Trying Sonos Actions does not work, playlists are empty, playing tracks is empty (previous does not work) etc.
Stop playing works (once I start a track manually from Sonos app), resume if paused works then.
Playing previous track results in: "GetPicture called for Zone - Living Room 2 url= http://10.0.0.147:1400/getaa?s=1&u=x...d8224%26sn%3d1 caused error: The remote server returned an error: (404) Not Found."
If I use "play radiostation" the drop down menu "select radiostation" remains empty on all players.
I only see my hardware players in the drop down menu, no groups.
Is this related?
Running the latest HS3 PI-Sonoscontroller 3.1.0.11.
Other problems:
Is this related?
