Dirk,
I am in the proces of reinstalling and recreating all devices and events for my installation. Hoping to eliminate events freezing here, something only I seem to experience.
I was in the progress of recreating the devices for the sonos plugin, but that is going very wrong here. If I activate the plugin for the first time on the new database, it is throwing errors while creating the parent devices. It does not create the child devices anymore. I have attached the HS3 log for this as "sonosfirststart.txt".
If I then restart the plugin it complains it finds devices which are not found in the corresponding ini file. Probably caused by the errors during the first start. Then it tries to create the child devices, which are created, but again throwing errors. Those devices are not created as child devices, causing parent/child relations not to be visible anymore. Leaving my devices in a mess. The created devices are not updated. This second start is also added as a log file.
On the config page, after the second start, the player table is adding 3 "?" devices, one less then the number of devices (playbar/sub/2xS3) that I have active. With each subsequent restart it is again adding 3 devices to the player table.
I don't know what is causing these errors?
Wim
Wim
