I have been very happy with the plug-in, once I understood some of the idiosyncrasies and learned the specific order in which things need to be done if renaming, changing configuration or deleting any Sonos devices.
The one small bug occurs if you delete a sonos device that is part of a linkgroup. If you delete the speaker, the plug-in properly removes the HS devices, removes the speaker from the Player Table and the Linkgroup Configuration table. It does not remove the device from the sonos.ini file where the "[LinkgroupZoneDestination]" is defined.
If you delete a speaker without manually editing the reference to it in that section of the settings, you will get these errors whenever the Linkgroup is called:
Nov-25 12:24:30 PM Sonos Error Error in HandleLinkingOn for LinkgroupZoneDestination = RINCON_949F3E05D3C601400 not found
Nov-25 12:24:29 PM Sonos Error Error in SaveLinkedPlayers with error: Object reference not set to an instance of an object.
Nov-25 12:24:28 PM Sonos Error Error in SaveLinkedPlayers with error: Object reference not set to an instance of an object.
Nov-25 12:24:28 PM Sonos Error Error in HandleLinkingOn for LinkgroupZoneDestination = RINCON_949F3E05D3C601400;30;1;1 not found
Deleting the entry for the deleted Sonos device will stop the errors.
