I wiped my squeezebox server… and decided to run pocoreplayer.
Picoreplayer runs on lms 8..1.x
Can’t downgrade to 7.9 (various reasons)
Problem… hs squeezebox plug-in has max target of 7.*
I know people are running hs3 plug-in on LMS 8.x
But can’t get it to install on LMS 8+
Following snippet from lms log shows it downloads, but won’t install because target is outside range
Any way to change the xml file to be max target=* instead of max target=7+?
Any and all help appreciated
07-18 14:15:34.1737] Slim::Networking::SimpleAsyncHTTP:nBody (129) status for http://arbwarea/squeezebox/repo.xml is 200 OK
[21-07-18 14:15:34.1744] Slim::Networking::SimpleAsyncHTTP:nBody (150) Done
[21-07-18 14:15:34.1794] Slim::Plugin::Extensions::Plugin::_parseXML (501) searching http://arbwarea/squeezebox/repo.xml for type: plugin target: unix version: 8.1.2
[21-07-18 14:15:34.1802] Slim::Plugin::Extensions::Plugin::_parseXML (517) entry HS3 does not match, bad target version [8.1.2 outside 7.4, 7+]
[21-07-18 14:15:34.1807] Slim::Plugin::Extensions::Plugin::_parseXML (589) found 0 extensions……..
