Here is version 1.6.0 Beta 1 of the SqueezeBox plugin, with one additional change since beta 0. I did some testing but would like to get more feedback before making it available via the updater. The release version of 1.6 will require HS2 2.3.0.33 or later in order to ensure the plugin is installed before HS2 finished its startup process (using msi installation - see HS2 2.3.0.33 beta notes).
To install:
Changes:
New scripting APIs:
Public Sub QueryConfiguration()
To install:
- Install the version available from the updater if not already installed
- Extract content of hspi_squeezebox_V1.6.0.1_Beta1.zip to HomeSeer home installation directory to overwrite HSPI_SQUEEZEBOX.dll
- Restart HomeSeer
Changes:
- SqueezeCenter security support: the SqueezeCenter username and password can be entered in the configuration page and if defined the plugin will login upon (re-)connection.
- Changed 1st device string per player from "({status})" to " is {status}". For example "Player1 (On)" will now be displayed as "Player1 is on".
- Added a new HS2 action called "SqueezeBox Playlist" to manipulate the playlist of a player. Supported actions are play item, add item, insert item, delete item and clear playlist.
- New API to interact with playlist. See below for signatures
- The end of library scan message from SqueezeCenter will trigger (re-)querying the number of artists, albums, songs, etc
- Tested with Squeezecenter 7.2.1 and 7.3.2
- Fixed "Shuffle off" and "Repeat off" action buttons in HS2 status page
- Fixed connection error 10047 (in beta 1) encountered by some users
New scripting APIs:
Queries SqueezeCenter configuration information such as version, number of artists, albums, and songs
Public Sub PlayerPlaylistPlay(ByVal playerName As String, ByVal item As String) Updates player playlist with item and starts playing item
Public Sub PlayerPlaylistAdd(ByVal playerName As String, ByVal item As String) Adds item to player playlist.
Public Sub PlayerPlaylistInsert(ByVal playerName As String, ByVal item As String) Inserts item to player playlist after currently played song.
Public Sub PlayerPlaylistDeleteItem(ByVal playerName As String, ByVal item As String) Delete item from player playlist.
Public Sub PlayerPlaylistClear(ByVal playerName As String)Clears player playlist
Public Sub PlayerSendCLICommand(ByVal playerName As String, ByVal command As String) Sends a CLI command for a specific player. Do not include the player reference in command(1st argument of command) and escape the command (URL encode) as required.
