Heater status and setpoints
  • Heater status and setpoints
    Im' converting my pool to salt this year and I bought the equipment with homeseer in mind. I have the plugin talking to my ps4 through the 232 thingy(as you can tell I'm new to this) and I can control my heater from the settings menu, however shouldn't I see a heater status and heater setpoint in those devices? Not 100% sure I have all the configurations set right. I'm pool only with 1 hayward heat pump heater.
    If it ain't broke, don't fix it!
    If I recall correctly, I had to change the label of my heater in the AquaConnect control panel to "Gas Heater" in order for the plug-in's heater control/status devices to work properly.
      Thanks Brady, That was it!
        Thanks for the assist jbbtex!
        The Plugin was programmed to look for Heater1 label = "Gas Heater" on the actual pool controller.
          happnatious1,
          I added a "Spa" configuration option to allow you to disable to Spa section and associated devices. You can try it out by disabling Aquaconnect from the Manage Plugins screen and then replace the HSPI_AQUACONNECT.exe file with the new compressed version I just added to this thread...
          http://board.homeseer.com/showthread.php?t=174354
          Then reenable the Aquaconnect plugin.
          Let me know how it goes.
          Thanks!
          Mike
