New To Plug-in
  • New To Plug-in
    It is up and working great when i use the control screen under Plug-in but when i access from my iPhone and the HS Client i was hoping to have the same graphic control. What did i do wrong or not install? I do have HS-Touch install.
    Welcome... Glad you are using my plug in.
    You have to create a screen using hstouch designer which displays the plug in website.
    The next issue you may face is the plug in website may not display through hstouch when you are not on you local lan. This may be because you have password protected homeseer Web pages if not on local subnet. A way around this is to vpn into your router to get local subnet ip address.
    Hope this helps!
    Mike
      Gotcha
      I was able using a vpn Tunnel and only the local WiFi to get to the web browser based screen, i was using the HomeSeer iPhone app. Thanks for the great app!
