Config for Jandy AUX
  • Config for Jandy AUX
    So I have AUX1, AUX2, AUX4, AUX5, AUX6, and AUX7 configured and they all appear in the list you are receiving from the Autelis. Can you add a way to configure those extra items for the plug-in, including Control?
    Tim
    pool heat:
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123090 0 0 0 1 0 0 0 0 0 0 0 0 94 60 99 77 76 63 61 F
    solar heat:
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123121 0 0 0 0 0 1 0 0 0 0 0 0 94 60 99 77 76 63 61 F
    spa heat:
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123152 0 0 0 0 1 0 0 0 0 0 0 0 94 60 99 77 76 63 61 F
    pump:
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123196 1 0 0 0 0 0 0 0 0 0 0 0 94 60 99 77 76 63 61 F
    pump and waterfall (spillway):
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123220 1 0 1 0 0 0 0 0 0 0 0 0 94 60 99 77 76 63 61 F
    (pump and) spa:
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123253 1 1 0 0 0 0 0 0 0 0 0 0 94 60 99 77 76 63 61 F
    Water Feature: (AUX1)
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123380 0 0 0 0 0 0 1 0 0 0 0 0 94 60 99 77 76 63 61 F
    Spa Jets: (AUX2)
    Pool Lights: (AUX4)
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123455 0 0 0 0 0 0 0 0 1 0 0 0 94 60 99 77 76 63 61 F
    Spa Lights: (AUX5)
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123492 0 0 0 0 0 0 0 0 0 1 0 0 94 60 99 77 76 63 61 F
    TalkStatus: (AUX6)
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123492 0 0 0 0 0 0 0 0 0 0 1 0 94 60 99 77 76 63 61 F
    MusicOn: (AUX7)
    DEBUG 8 6520 00110100 0 664 0 1.6.5 1496123492 0 0 0 0 0 0 0 0 0 0 0 1 94 60 99 77 76 63 61 F
    not sure I understand, all the AUX should already appear as Homeseer devices with On/Off controls. Is that not the case for you?
    If so, what version of the plug-in are you running?
    Could you paste the following urls in a browser (replacing "your.ip.address" by the actual ip address of your Autelis controller) and post the xml results:
    http://your.ip.address/names.xml
    http://your.ip.address/status.xml
    thanks
      NO, it didn't fully populate. I've just got all the basics. Brand new HS system, so:
      I'm running the latest HS3 and 3.0.0.14 (just upgraded to 3.0.0.15 which had no impact)
      Odd thing is that the name.xml URL gives me an error 404. That must be the problem. Can I manually edit my ini file? I worry that my ISY specific firmware version 1.6.5 might be the problem, although I don't know why they would eliminate the names.xml page?
      Here is status.xml:
      <response>
      <system>
      <runstate>8</runstate>
      <model>6520</model>
      <dip>00110100</dip>
      <opmode>0</opmode>
      <vbat>659</vbat>
      <lowbat>0</lowbat>
      <version>1.6.5</version>
      <time>1496199029</time>
      </system>
      <equipment>
      <pump>0</pump>
      <pumplo/>
      <spa>0</spa>
      <waterfall>0</waterfall>
      <cleaner/>
      <poolht2/>
      <poolht>0</poolht>
      <spaht>1</spaht>
      <solarht>1</solarht>
      <htpmp/>
      <aux1>0</aux1>
      <aux2>0</aux2>
      <aux3/>
      <aux4>0</aux4>
      <aux5>0</aux5>
      <aux6>0</aux6>
      <aux7>0</aux7>
      <aux8/>
      <aux9/>
      <aux10/>
      <aux11/>
      <aux12/>
      <aux13/>
      <aux14/>
      <aux15/>
      <aux16/>
      <aux17/>
      <aux18/>
      <aux19/>
      <aux20/>
      <aux21/>
      <aux22/>
      <aux23/>
      </equipment>
      <temp>
      <poolsp>94</poolsp>
      <poolsp2>60</poolsp2>
      <spasp>99</spasp>
      <pooltemp>76</pooltemp>
      <spatemp>76</spatemp>
      <airtemp>64</airtemp>
      <solartemp>64</solartemp>
      <tempunits>F</tempunits>
      </temp>
      </response>
      Tim
      I also see a startup error logged:
      5/30/2017 7:38:38 PM ~!~Autelis~!~INFO WebException: ProtocolError The remote server returned an error: (404) Not Found.
      5/30/2017 7:38:39 PM ~!~Autelis~!~INFO WebException: ProtocolError The remote server returned an error: (404) Not Found.Startup Complete, 4 errors detected, check the log for more information.
        do you mean Autelis specific firmware? what's specific about it?
        I think they may have added the names.xml recently. The latest firmware for Jandy is 1.6.10:
        http://www.autelis.com/downloads/pc1...ADV-1.6.10.jar
          in version 3.0.0.16 (available here), the AUX devices are created even if the names.xml is not available. Then you can rename the devices to anything you want.
            Here is status.xml:
            <response>
            <system>
            <model>6520</model>
            <dip>00110100</dip>
            <opmode>0</opmode>
            <vbat>659</vbat>
            <lowbat>0</lowbat>
            </system>
            <equipment>
            <pump>0</pump>
            <pumplo/>
            <spa>0</spa>
            <cleaner/>
            <poolht2/>
            <poolht>0</poolht>
            <spaht>1</spaht>
            <htpmp/>
            <aux1>0</aux1>
            <aux2>0</aux2>
            <aux3/>
            <aux4>0</aux4>
            <aux5>0</aux5>
            <aux6>0</aux6>
            <aux7>0</aux7>
            <aux8/>
            <aux9/>
            <aux10/>
            <aux11/>
            <aux12/>
            <aux13/>
            <aux14/>
            <aux15/>
            <aux16/>
            <aux17/>
            <aux18/>
            <aux19/>
            <aux20/>
            <aux21/>
            <aux22/>
            <aux23/>
            </equipment>
            <temp>
            <poolsp>94</poolsp>
            <spasp>99</spasp>
            </temp>
            </response>
            Tim
            I'm also getting the startup errors for Autelis mentioned above. Any ideas what the issue might be?
            7/23/2017 9:21:43 AM ~!~Autelis~!~INFO WebException: ProtocolError The remote server returned an error: (404) Not Found.
            7/23/2017 9:21:43 AM ~!~Autelis~!~INFO WebException: ProtocolError The remote server returned an error: (404) Not Found.Startup Complete, 2 errors detected, check the log for more information.
              what kind of Autelis controller do you have? what's your firmware? and what's your plugin version?
                Autelis Jandy PC100JZL Legacy software version 1.6.2 (legacy) for Jandy RS pool controllers that are <= rev HH firmware. HS version 3.0.0.318 Autelis plugin version 3.0.0.16. Thanks
                Sent from my SM-G930T using Tapatalk
                  I'm still not sure if the Jandy legacy firmware is compatible with this plugin. Could you paste the following urls in a browser (replacing "your.ip.address" by the actual ip address of your Autelis controller) and post the xml results:
                  http://your.ip.address/lights.xml
                  thanks
                    thanks
                    http://your.ip.address/names.xml - 404: File not found
                    http://your.ip.address/status.xml - <response>
                    <system>
                    <runstate>1</runstate>
                    <model>0</model>
                    <dip>00000000</dip>
                    <opmode>0</opmode>
                    <vbat>0</vbat>
                    <lowbat>0</lowbat>
                    <version>1.6.2</version>
                    <time>1500913644</time>
                    </system>
                    <equipment>
                    <pump>1</pump>
                    <pumplo/>
                    <spa>0</spa>
                    <waterfall/>
                    <cleaner/>
                    <poolht2/>
                    <poolht>0</poolht>
                    <spaht>0</spaht>
                    <aux1>0</aux1>
                    <aux2>0</aux2>
                    <aux3>0</aux3>
                    <aux4>0</aux4>
                    <aux5>0</aux5>
                    <aux6>0</aux6>
                    <aux7>0</aux7>
                    <aux8>0</aux8>
                    <aux9>0</aux9>
                    <aux10>0</aux10>
                    <aux11>0</aux11>
                    <aux12/>
                    <aux13/>
                    <aux14/>
                    <aux15/>
                    <aux16/>
                    <aux17/>
                    <aux18/>
                    <aux19/>
                    <aux20/>
                    <aux21/>
                    <aux22/>
                    <aux23/>
                    </equipment>
                    <temp>
                    <poolsp>0</poolsp>
                    <poolsp2>0</poolsp2>
                    <spasp>0</spasp>
                    <pooltemp>83</pooltemp>
                    <spatemp>88</spatemp>
                    <airtemp>68</airtemp>
                    <solartemp>0</solartemp>
                    </temp>
                    </response>
                    http://your.ip.address/lights.xml - 404: File not found
                    The plugin otherwise works fine for me.
                      ok, so the errors you see at startup are due to names.xml and lights.xml not being found, they are not mandatory so you can just ignore the errors, I will try to log them at debug level in the next version.
                        Thanks for the quick reply.
