Autelis availability?
    #31
    Originally posted by baudfather View Post
    +1 if spud can create a plugin for https://github.com/tagyoureit/nodejs-poolController which seems to be the only viable option for those who want to integrate their pool controller. I'd prefer the plug and play solution from Autelis, but can't keep holding my breath for their new version.
    Getting bids to build a pool and 2 of the builders use Pentair. Would absolutely love a plugin to be built maybe using nodejs and an adapter. If I end up with Pentair, would be willing to allow my system to be opened up for dev and testing.
      #32
      +2 for a plugin
      Devoir
        #33
        Signed contract with builder today. Pentair EasyTouch and ScreenLogic2 going in. Hoping there will be a plug-in for HomeSeer sooner rather than later.
          #34
          Looks like they may not be dead - autelis.com now indicates a return in early 2020. I wonder if the API has changed in their new products, which would mean that Spud's PI may not work.
            #35
            Is this board (ARDUINO MKR 485 SHIELD) work?
              #36
              This is what is available
              https://www.troublefreepool.com/thre...-guide.218514/
              Click image for larger version  Name:	PoolController EasyTouch 8.JPG Views:	0 Size:	110.8 KB ID:	1424276
              There are bindings for Vera, SmartThings, Habitat, Homebridge, Siri, Eve, InfluxDB...
              There is a way to interface with Homeseer by MQTT, just requires more gray matter then I have at the moment.
              Link to the MQTT binding instructions;
              https://github.com/tagyoureit/nodejs...ns-in-2.0#mqtt
              I have a ready to go RPI, ABS case w 40mm fan, RS484 adapter, power supply, and preloaded software on a 32GB SD card, for anyone willing to write a Homeseer binding.
                #37
                I don't think anyone is working on this. Another way to skin the cat is have Hubitat talk to the nodejs controller and get that info back into homeseer using the Hubitat Elevation plugin. Seems to be integrated into hubitat fine now. Or maybe post this request into the big5 forum, as it could be integrated that way as well. Folks in that forum have been good about building interfaces for services like this.
                thx
                mike
                  #38
                  Moving to a new home with a Jandy controller. I have an Autelis in the current home and it works well enough. The web interface is clunky and the password NEVER gets saved in my phone. I guess its just a bunch of relays really? Doesn't seem impossible to replicate but not sure I care enough . Anyone else doing anything to remotely control Jandy Aqualink?
                    #39
                    You might take a look aqualinkd. This is my weekend project I work on now. It works well but you have to use with VPN or integrate to home automation. So far I get to the point integration. Check it out you might like it.
                      #40
                      Does this use their aqualink hardware?
                        #41
                        It pulls the data from the panel. Google aqualinkd wiki. You will have all the information you need.
