2 Interfaces -- Missing Devices
  • skavan
    Hi... I think this did the trick....will play some more and let you know.
    s.
  • spud
    please test version 3.0.0.21 available here and let me know.
  • spud
    good catch there is a conflict between the 2 instances. I think you are the first one to ever use this plugin with 2 instances.
    I will fix this asap, thanks for reporting.
  • skavan
    started a topic 2 Interfaces -- Missing Devices
    Just bought and installed the excellent plugin.
    I have two autelis interfaces (#1: main pool and spa, #2: separate spa).
    The first interface seems to create all the relevant devices (lights, pumps, heaters, temp etc..).
    But the second interface only creates 3 devices (salt, chlorination x 2).
    If I disable, delete, kill the ini file and reinstall...but set it up in reverse, (second interface as main interface) -- then once again, the devices are created properly for the first/main plugin interface...but not the second.
    Not sure if its overwriting devices or simply not creating them.
    Help!
