High CPU usage
    High CPU usage
    Spud, I thought I mentioned this on another thread with you, but now can not find it...
    Could you look over the plugin for CPU usage, at least on Linux its the highest CPU usage of all my plugins (BLRadar is close) but all the others are 6x or more less CPU usage, If there are any metrics or anything I can do to help figure out why (unless you thin there is an inherent reason, the network connection and xml parsing don't seem like they would explain it...) please just lmk.
    Best
    Bill
    p.s. Screenshot to show relative weights of the various plugins.
Name:	Screen Shot 2018-11-11 at 4.08.25 PM.png
    just curious, what's CpsLinks ?
      unless I'm missing something your screenshot shows the Autelis plugin at 0.7% CPU usage which is not the highest CPU usage among the plugins.
      is that the memory usage you are worried about? If so, does the mem% go instantly to 3.9% when you restart the plugin?
        That is showing the current usage, just happened to grab it as a reasonable rate. Look at the TIME+ column which is the total schedule and executed quanta for the process. There you will see the 6x delta I mentioned.
          Lol Mr. Eagle Eye. Another plugin I am working on, its for quickly connecting device together. E.g. device 1 is set to off then set device 2 to x. While you can do this with events today, I prefer those type of things tied to the devices themselves. Ill send you some screen shots.
            Got it.
            I found one potential problem with Xml parsing, and I have optimized that in version 3.0.0.24 available in the Beta section of the updater.
            Please test it and let me know.
              Got it.
              Thanks, Ill go try it now.
              Bill
                Got it.
                Unfortunately I am not seeing any change with this version, the high overall cpu times stays...
                  Spud, any other ideas to try, the issue definitely remains...
Name:	Screen Shot 2018-12-09 at 5.34.02 PM.png
