Plugin problems
  • bsobel
    Please install and test version 3.0.0.25 available in the beta section of the updater.
    In this version I fixed the race condition with polling, as well as the problem when shutting down the plugin and I added the possibility to log to a file.
    It will still take time on first poll because you have a lot of devices, but it should not create duplicate devices anymore.
    Your logs show that the pumps.xml and chem.xml are missing (404 error), I'm not sure if this is because of your firmware or because there is no such information for your system.
    It looks like you have a Jandy controller with firmware 1.6.9, right? You may want to try to upgrade to a more recent firmware, looks like current one is 1.6.13: http://www.autelis.com/forum/viewtopic.php?f=4&t=817
    Thanks, will update today and do the firmware once Im actually there (just in case)...
  • spud
  • bsobel
    One minor note, it appears that while trying to create devices the plugin refuses to exit which if attempted after awhile makes HS think the plugin died. Explains my issue last night of not even being able to bring up the config page.
  • bsobel
    Originally posted by bsobel View Post
    I did a test. Set the poll to 5 minutes and tried again. Plugin was still creating devices at that point and around 6 minutes in I started getting a few duplicates. Not as many, just hit the non-created devices. Sounds like a definite race condition. LMK if I should try anything else. I also use the poll command when I suspect something has changed, so Im hoping that will conflict during startup and cause the same issues when used...
    My poll event fired so calling that (not surprisingly) also causes the same issue. I'm going to disable the event and try again.
  • bsobel
  • bsobel
    Thanks, will do. I have about 2500 devices but the the DB has wrapped over 10k with adds/deletes (not sure those matter).... My concern with the suggestion is that somehow I wound up with duplicate devices even after the first set was created correctly for months. Guessing a race between your device enumerator and the poll, so I will set the poll to something higher for now. One suggestion is to cache the device Ids in the ini file and only enumerate if not found....
  • spud
    I think the problem is that the first poll is very slow because it has to create all the devices and it has to scan all your existing devices (how many do you have?) to make sure they do not already exist. As it takes more than 2 minutes the second poll is started and create devices too.
    I will prevent this from happening and try to speed up the creation process. In the meantime here is workaround for you: set the polling interval to 60 minutes, delete all the existing Autelis devices then restart the plugin. Once all the devices are created, set the polling interval back to 2 minutes.
  • bsobel
    Here you go, everything in the log from the restart.
  • bsobel
    Jan-01 7:57:00 PM Autelis DEBUG 404: File not found
    Jan-01 7:57:00 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:57:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:57:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:57:00 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546401420 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 46 F
    Jan-01 7:57:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:54:41 PM Autelis DEBUG 404: File not found
    Jan-01 7:54:41 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:54:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:54:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:54:40 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546401280 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 46 F
    Jan-01 7:54:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:52:14 PM Autelis DEBUG 404: File not found
    Jan-01 7:52:14 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:52:14 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:52:14 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:52:14 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546401133 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 46 F
    Jan-01 7:52:14 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:49:54 PM Autelis DEBUG 404: File not found
    Jan-01 7:49:54 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:49:54 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:49:54 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:49:54 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400994 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 46 F
    Jan-01 7:49:54 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:47:41 PM Autelis DEBUG 404: File not found
    Jan-01 7:47:41 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:47:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:47:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:47:41 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400860 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 46 F
    Jan-01 7:47:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:46:22 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400781 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 46 F
    Jan-01 7:46:21 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:45:09 PM Autelis DEBUG 404: File not found
    Jan-01 7:45:09 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:45:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:45:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:45:09 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400709 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:45:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:44:52 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400691 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:44:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:42:51 PM Autelis DEBUG 404: File not found
    Jan-01 7:42:51 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:42:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:42:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:42:51 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400570 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 55 44 F
    Jan-01 7:42:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:42:37 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400556 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 55 44 F
    Jan-01 7:42:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:40:37 PM Autelis DEBUG 404: File not found
    Jan-01 7:40:37 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:40:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:40:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:40:36 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400436 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 55 43 F
    Jan-01 7:40:36 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:38:18 PM Autelis DEBUG 404: File not found
    Jan-01 7:38:18 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:38:18 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:38:18 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:38:17 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400298 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 43 F
    Jan-01 7:38:17 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:35:55 PM Autelis DEBUG 404: File not found
    Jan-01 7:35:55 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:35:55 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:35:55 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:35:55 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400155 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 43 F
    Jan-01 7:35:55 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:34:22 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400062 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 43 F
    Jan-01 7:34:22 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:33:37 PM Autelis DEBUG 404: File not found
    Jan-01 7:33:37 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:33:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:33:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:33:36 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546400016 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 44 F
    Jan-01 7:33:36 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:31:10 PM Autelis DEBUG 404: File not found
    Jan-01 7:31:10 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:31:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:31:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:31:10 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399870 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 44 F
    Jan-01 7:31:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:30:37 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399837 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 44 F
    Jan-01 7:30:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:28:54 PM Autelis DEBUG 404: File not found
    Jan-01 7:28:54 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:28:54 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:28:54 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:28:54 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399734 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:28:54 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:26:41 PM Autelis DEBUG 404: File not found
    Jan-01 7:26:41 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:26:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:26:40 PM Autelis DEBUG 404: File not found
    Jan-01 7:26:40 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:26:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:26:40 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399600 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:26:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:24:22 PM Autelis DEBUG 404: File not found
    Jan-01 7:24:22 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:24:22 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:24:22 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:24:22 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399462 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:24:22 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:22:03 PM Autelis DEBUG 404: File not found
    Jan-01 7:22:03 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:22:03 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:22:03 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:22:02 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399323 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:22:02 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:21:37 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399297 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 45 F
    Jan-01 7:21:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:19:48 PM Autelis DEBUG 404: File not found
    Jan-01 7:19:48 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:19:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:19:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:19:48 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399188 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 44 F
    Jan-01 7:19:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:17:31 PM Autelis DEBUG 404: File not found
    Jan-01 7:17:31 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:17:31 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:17:31 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:17:31 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546399051 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 44 F
    Jan-01 7:17:30 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:15:00 PM Autelis DEBUG 404: File not found
    Jan-01 7:15:00 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:15:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:15:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:15:00 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398900 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 54 44 F
    Jan-01 7:15:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:12:44 PM Autelis DEBUG 404: File not found
    Jan-01 7:12:44 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:12:44 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:12:44 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:12:43 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398764 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 55 44 F
    Jan-01 7:12:43 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:10:28 PM Autelis DEBUG 404: File not found
    Jan-01 7:10:28 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:10:28 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:10:28 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:10:28 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398628 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 7:10:27 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:08:10 PM Autelis DEBUG 404: File not found
    Jan-01 7:08:10 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:08:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:08:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:08:10 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398490 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 7:08:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:05:52 PM Autelis DEBUG 404: File not found
    Jan-01 7:05:52 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:05:52 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:05:52 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:05:52 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398352 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 55 44 F
    Jan-01 7:05:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:03:26 PM Autelis DEBUG 404: File not found
    Jan-01 7:03:26 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:03:26 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:03:26 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:03:26 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398206 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 7:03:25 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 7:01:09 PM Autelis DEBUG 404: File not found
    Jan-01 7:01:09 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 7:01:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 7:01:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 7:01:09 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546398069 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 7:01:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:58:53 PM Autelis DEBUG 404: File not found
    Jan-01 6:58:53 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:58:53 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:58:53 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:58:52 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397932 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 6:58:52 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:56:39 PM Autelis DEBUG 404: File not found
    Jan-01 6:56:39 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:56:39 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:56:39 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:56:39 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397799 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 6:56:39 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:56:12 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397772 1 0 0 0 0 0 0 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 6:56:12 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:54:09 PM Autelis DEBUG 404: File not found
    Jan-01 6:54:09 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:54:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:54:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:54:09 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397649 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 6:54:08 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:52:22 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397542 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 44 F
    Jan-01 6:52:22 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:51:51 PM Autelis DEBUG 404: File not found
    Jan-01 6:51:51 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:51:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:51:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:51:51 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397511 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 45 F
    Jan-01 6:51:51 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:49:38 PM Autelis DEBUG 404: File not found
    Jan-01 6:49:38 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:49:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:49:37 PM Autelis DEBUG 404: File not found
    Jan-01 6:49:37 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:49:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:49:37 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397377 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 45 F
    Jan-01 6:49:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:47:19 PM Autelis DEBUG 404: File not found
    Jan-01 6:47:19 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:47:19 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:47:19 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:47:19 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397239 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 45 F
    Jan-01 6:47:19 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:44:56 PM Autelis DEBUG 404: File not found
    Jan-01 6:44:56 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:44:56 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:44:56 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:44:56 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546397096 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 45 F
    Jan-01 6:44:55 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:42:25 PM Autelis DEBUG 404: File not found
    Jan-01 6:42:25 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:42:25 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:42:25 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:42:25 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396945 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 45 F
    Jan-01 6:42:24 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:40:24 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396824 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 45 F
    Jan-01 6:40:24 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:39:58 PM Autelis DEBUG 404: File not found
    Jan-01 6:39:58 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:39:58 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:39:58 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:39:58 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396798 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 46 F
    Jan-01 6:39:58 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:37:45 PM Autelis DEBUG 404: File not found
    Jan-01 6:37:45 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:37:45 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:37:45 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:37:45 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396664 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 46 F
    Jan-01 6:37:44 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:35:21 PM Autelis DEBUG 404: File not found
    Jan-01 6:35:21 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:35:21 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:35:21 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:35:21 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396520 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 46 F
    Jan-01 6:35:21 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:33:00 PM Autelis DEBUG 404: File not found
    Jan-01 6:33:00 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:33:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:33:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:33:00 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396380 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 46 F
    Jan-01 6:33:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:32:37 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396357 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 46 F
    Jan-01 6:32:37 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:30:41 PM Autelis DEBUG 404: File not found
    Jan-01 6:30:41 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:30:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:30:41 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:30:40 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396240 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 47 F
    Jan-01 6:30:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:28:25 PM Autelis DEBUG 404: File not found
    Jan-01 6:28:25 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:28:25 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:28:25 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:28:25 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546396104 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 47 F
    Jan-01 6:28:24 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:26:00 PM Autelis DEBUG 404: File not found
    Jan-01 6:26:00 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:26:00 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:25:59 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:25:59 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395959 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 47 F
    Jan-01 6:25:59 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:23:46 PM Autelis DEBUG 404: File not found
    Jan-01 6:23:46 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:23:46 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:23:46 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:23:45 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395825 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 47 F
    Jan-01 6:23:45 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:21:27 PM Autelis DEBUG 404: File not found
    Jan-01 6:21:27 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:21:27 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:21:27 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:21:27 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395686 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 47 F
    Jan-01 6:21:26 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:19:02 PM Autelis DEBUG 404: File not found
    Jan-01 6:19:02 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:19:02 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:19:02 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:19:02 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395542 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 47 F
    Jan-01 6:19:02 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:16:48 PM Autelis DEBUG 404: File not found
    Jan-01 6:16:48 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:16:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:16:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:16:48 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395408 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 47 F
    Jan-01 6:16:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:14:27 PM Autelis DEBUG 404: File not found
    Jan-01 6:14:27 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:14:27 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:14:27 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:14:26 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395266 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 53 47 F
    Jan-01 6:14:26 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:14:22 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395262 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 53 47 F
    Jan-01 6:14:22 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:12:06 PM Autelis DEBUG 404: File not found
    Jan-01 6:12:06 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:12:06 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:12:06 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:12:06 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546395125 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 53 48 F
    Jan-01 6:12:05 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:09:47 PM Autelis DEBUG 404: File not found
    Jan-01 6:09:47 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:09:47 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:09:47 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:09:47 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394986 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 6:09:46 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:07:23 PM Autelis DEBUG 404: File not found
    Jan-01 6:07:23 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:07:23 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:07:23 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:07:23 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394843 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 6:07:23 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:04:56 PM Autelis DEBUG 404: File not found
    Jan-01 6:04:56 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:04:56 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:04:56 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:04:55 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394695 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 6:04:55 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:02:42 PM Autelis DEBUG 404: File not found
    Jan-01 6:02:42 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:02:42 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:02:42 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:02:42 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394561 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 6:02:42 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 6:00:11 PM Autelis DEBUG 404: File not found
    Jan-01 6:00:11 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 6:00:11 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 6:00:11 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 6:00:11 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394410 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 6:00:10 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:57:48 PM Autelis DEBUG 404: File not found
    Jan-01 5:57:48 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:57:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:57:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:57:48 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394268 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 5:57:48 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:55:30 PM Autelis DEBUG 404: File not found
    Jan-01 5:55:30 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:55:30 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:55:30 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:55:30 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394130 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 5:55:30 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:54:52 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546394092 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 48 F
    Jan-01 5:54:52 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:53:04 PM Autelis DEBUG 404: File not found
    Jan-01 5:53:04 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:53:04 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:53:03 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:53:03 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546393983 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 49 F
    Jan-01 5:53:03 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:50:47 PM Autelis DEBUG 404: File not found
    Jan-01 5:50:47 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:50:47 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:50:47 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:50:47 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546393846 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 49 F
    Jan-01 5:50:47 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:48:28 PM Autelis DEBUG 404: File not found
    Jan-01 5:48:28 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:48:28 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:48:28 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:48:27 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546393707 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 49 F
    Jan-01 5:48:27 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:46:09 PM Autelis DEBUG 404: File not found
    Jan-01 5:46:09 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:46:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:46:09 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:46:08 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546393568 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 54 49 F
    Jan-01 5:46:08 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:43:40 PM Autelis DEBUG 404: File not found
    Jan-01 5:43:40 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:43:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:43:22 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:43:11 PM Autelis DEBUG 404: File not found
    Jan-01 5:43:11 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:43:11 PM Autelis INFO CMD SENT: http://10.1.0.249:80/chem.xml?
    Jan-01 5:43:11 PM Autelis INFO CMD SENT: http://10.1.0.249:80/pumps.xml?
    Jan-01 5:29:53 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546392583 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 56 49 F
    Jan-01 5:29:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:27:44 PM Autelis DEBUG 8 6520 11100000 0 615 0 1.6.9 1546392463 1 0 0 0 0 0 1 0 0 0 0 0 90 60 99 54 0 55 49 F
    Jan-01 5:27:43 PM Autelis INFO CMD SENT: http://10.1.0.249:80/status.xml?
    Jan-01 5:27:43 PM Autelis DEBUG 404: File not found
    Jan-01 5:27:43 PM Autelis DEBUG WebException: ProtocolError The remote server returned an error: (404) Not found.
    Jan-01 5:27:43 PM Autelis INFO CMD SENT: http://10.1.0.249:80/lights.xml?
    Jan-01 5:27:42 PM Autelis DEBUG Cleaner Low Speed Overflow Air Blower Lights Heat Pump Gas Heater AUX8 AUX9 AUX10AUX11 AUX12 AUX13 AUX14 AUX15 AUX16 AUX17 AUX18 AUX19 AUX20 AUX21 AUX22 AUX23
    Jan-01 5:27:40 PM Autelis INFO CMD SENT: http://10.1.0.249:80/names.xml?
    Jan-01 5:27:40 PM Autelis INFO Autelis version 3.0.0.24
  • spud
    There is no log file, the logs are written to the HS logs.
    So in the log page when the plugin polls the Autelis controller you should at least see the request and response sent/received by the plugin. The devices are created on the first poll.
  • bsobel
    Bump. No log file I can see, same duplicate device issue.
  • bsobel
    Ok set plugin to debug logging. Stopped plugin. Deleted all Autelis devices. Restarted. Double devices created, but I don't see any obvious log file and nothing with Autelis in the name. The HS log doesn't contain anything other than the plugin startup information, where should I be looking?
  • bsobel
    It is an Autelis 6520. Polling is set to 2 minutes. And yes, happy to but won't be back there until probably tomorrow. Will do as soon as I arrive. FYI the devices were overall slowly created (took about 10 minutes for them all to show up) but the duplicates where all created very quickly, like 10 seconds or so apart...
  • spud
    What kind of Autelis controller do you have?
    What is the poll interval set to?
    Could you provide a debug log of the plugin start after deleting all the Autelis devices?
  • bsobel
    The second device created seems to be the working one, the first one is 'dead'. Explains why my config was broke, the plugin created duplicated I never noticed since they were not in the same building/room as the pool . Those became the 'real' devices while the original devices all my events are based on where orphaned. Not sure when this occurred (which build) but right now this seems fully reproducible if you want me to try something.
