pH and ORP devices
    pH and ORP devices
    Hi Spud,
    I have been using the plug-in for several years and all is great. I plan on adding pH control, however I don't see the devices for pH and ORP created in HS3 by the plugin as I can see in your user guide.
    I plan on adding the Pentair intellichem and connect it to the Suntouch (through the comm port) as indicated in their manual.
    I have a Pentair Suntouch controller connected to the Autelis device.
    The Autelis device has firmware version 1.6.6
    The Autelis plug-in is version: 3.0.0.26
    Homeseer version HS3 Pro Edition 3.0.0.293
    In the log I see:
    INFO CMD SENT: http://10.0.0.123:80/chem.xml?
    then
    DEBUG 1 0 0 0 0 00,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 ,0,0,0,128,0,2,0,0,0,0,0
    Through the Autelis web page I see the value of pH and ORP as zero, shouldn't I have a device pH = 0 and ORP =0?
    As always thanks for your help
    Chris
    Hi Spud,
    I updated the Autelis firmware to the latest which is 1.6.7, restarted the plug-in and it didn't create the pH and ORP devices.
    Chris
      I can't really see what's going with the log line you posted because HS is stripping out the xml tags.
      Could you either
      paste this url in a browser: http://10.0.0.123:80/chem.xml? and post the reponse you get
      or
      enable log to file and post the content of Logs/Autelis.txt
      thanks
        Hi ,
        I used the browser and got this response.
        <response>
        <chlor>
        <chloren>0</chloren>
        <poolsp/>
        <spasp/>
        <salt/>
        <super/>
        <chlorerr/>
        <chlorname/>
        </chlor>
        <ichem>
        0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,128,0,2,0,0,0,0,0
        </ichem>
        </response>
        Thanks for your help,
        Chris
          I tried to simulate this on my system by importing the xml you posted, and I successfully got the pH and ORP devices created :Click image for larger version
          In the config page you have type set to "Pentair Intellitouch , EasyTouch or SunTouch" right?
          Are you sure the device are not created? make sure the filters on the device management are not hiding them
            1000 Apologies, yes they had been created and they had been "filtered" on the device management page.
            Sorry to bother you...a rookie mistake by someone who should know better.
            Chris
