Pentair IntelliCenter - Homeseer integration
    I have a Pentair IntelliCenter pool system. It currently supports both a website and phone app to remotely control the system. I would like to integrate with HS. Would Spud's Autelis Pool Control plug-in support this system? Would the Autelis controller still be a requirement as the system already has network connectivity. Please advise. Thanks...
    I used that plugin for the Pentair Easytouch. I have to use the Autelis. From what I have read the plugin depends on the Autelis.
      Thank you for the response. I've reached out to Autelis to understand when their devices will be available.
        Were able to reach them? I think they are out of business...
        mike
          I sent an email to Autelis in early December 2019 but with no response..... are there any other options for this integration?
            There is semi-active development on NodeJS-poolcontroller which has an MQTT extension that can interface with mscMQTT. Version 6.0 is in the works and has lots of improvements over the current version, though the extensions aren't ready yet. Once the new version is released, I think it's the best option out there. https://github.com/tagyoureit/nodejs-poolController
              https://shop.homeseer.com/products/s...plugin-for-hs4
                That doesn't work for intellicenter though does it? Only Screen logic?
                  I have only tested on the ScreenLogic Protocol Adapter
Name:	SL Prototol Adapter.png
