Maybe works on other Autelis controllers?
  • spud
    Cool! Thank you for testing it.
    FYI, the plugin is now in the store: http://store.homeseer.com/store/Spud...P1910C155.aspx
    and updater
  • sdesbles
    Works Great
    Spud, your plugin is working great. Have not had any issues. In fact, I added buttons to our HStouch-screens to turn on the pools lights and spa and let the family have at it. They are thrilled to finally control the pool easily.
    And of course, enabled voice control via your Kinect plugin to do the same. Feel so futuristic now :-)
    Thanks for adding the Jandy support.
    Scott
  • sdesbles
    3.0.0.6 seems to be working fine. Will play with it over the next few days but so far so good.
    Thanks for updating it to support the Jandy/Zodiac controllers. Happy to compensate you when ready.
  • spud
    sorry again, I forgot to remove some debugging statements that helped me test with a local file instead of a http request.
    I have uploaded version 3.0.0.6 with the fix.
    thanks
  • sdesbles
    Error
    Getting the following error, looks like not grabbing the XML file?
    RROR System.IO.FileNotFoundException: Could not find file 'C:\Program Files\HomeSeer HS3\status.xml'. File name: 'C:\Program Files\HomeSeer HS3\status.xml' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamReader..ctor(String path, Encoding encoding, Boolean detectEncodingFromByteOrderMarks, Int32 bufferSize, Boolean checkHost) at System.IO.StreamReader..ctor(String path, Encoding encoding) at HSPI_Autelis.JandyController.GetStatusCmd() at HSPI_Autelis.AutelisApp.OnPollTimerEvent(Object sender, ElapsedEventArgs e)
  • spud
    oops, sorry, it's fixed now
  • sdesbles
    The zip file in the thread says 3.0.0.4 Installed it and indeed it is 3.0.0.4.
  • spud
    In version 3.0.0.5 (available here), I have added support for Jandy/Zodiac controllers.
    Please test and let me know.
  • sdesbles
    Awesome, happy to test whenever you are ready.
  • spud
    no the current version only work with Pentair systems, but it would be quite easy to adapt it for Jandy/Zodiac. So I'm going to do it and I will let you know when it's done because I will need some testers
  • sdesbles
    started a topic Maybe works on other Autelis controllers?
    Hi Spud,
    I have the Autelis pool control for Jandy/Zodiac. I have been writing a script to perform some basic polling/control via the http/xml interface when I saw your plugin post.
    Do you think it will work with the Jandy/Zodiac version? Happy to give it a go if you think it might.
