Will this work with PDA Aqualink Autelis controller (Model Number: PC100JZPDA). This version of controller appears less robust and I would like to know if it will work? It looks like the web interface only emulates a keypad but I am not sure.
Will this plugin work with PDA Aqualink?
This plugin is compatible with the Jandy/Zodiac controller (Model Number: PC100JZ)
I'm not sure if the Jandy Zodiac PDA controller (Model Number: PC100JZPDA) supports the same http API. I have emailed Autelis to know, I'll let you know when they answer me.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
here is Autelis response:
Unfortunately the PDA system is limited and locks out the required interfaces to support the API. So it is not compatible.
But PDA systems can be upgraded to RS systems in 2 ways:
1. install a compatible RS PPD chip or CPU board into the existing control board, or
2. replace the whole control board with an RS version.
As long as the RS firmware is revision M or greater the PDA remote will still work as an aqua palm remote control.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
