Matt,
Now that things seem to be operating correctly, I am "all in" on this app. I've removed the automation I was using through the iAquaLink app, and have events that are triggering lights on/off, pump on/off, spa on/off, etc. I have an event and virtual device which is triggered if the Freeze Protection has come on. If so, my other events trigger (or not) based on the pump running outside the hours I already have it set up. I set up pump run times based on Spring/Fall, Winter, and Summer, so all I have to do is turn on a Virtual device (Winter, Spring/Fall, or Summer) to change the run times I want depending on the weather/time of year, for the pump, lights, and more. Lots more flexibility thanks to you.
