How to tell if pump is running?
  • How to tell if pump is running?
    Hi Mat -
    I just installed the plug-in and see it recognized as a device. However, the options I see when trying to create an event are extremely limited. This may be a function of the Jandy iQPUMP01. All I'm really trying to do is say "is the pump currently running?" Maybe you could suggest a syntax or value.
    I see two devices:
Name:	MARS-2020-05-22 11_12_43-HomeSeer Web Control.png
    In the event, I was hoping to see something like "Pump has been ON for at least X minutes." But instead the only options are custom value or Error State. What custom value would indicate it's running?
    Thanks again. Sorry if these are really basic questions. I am very new to this stuff.
    nordicnn, you can create an event which starts a timer when the pump turns on, and then use that timer as a basis to trigger your Main Pump event. You can have the timer stop via another event that sees the pump turn off. And in the Main Pump event, just reset/restart the timer depending on what you want the timer to be doing.
      Thanks mdavison . I think that is basically what I want to do -- just as you described. However, I can't figure out the syntax for seeing if the pump has turned on. The other screenshots I see from folks using this plugin have lots of options and variables. Mine doesn't seem to have anything, making me think it is configured correctly or is not communicating.
        nordicnn, try this:
Name:	Screenshot 2020-05-27 07.58.42.png
          Thanks for those screenshots. When I specify "Pump Zodiac Pump" and then "changes and becomes," the is no On option. I only get as shown below.
            Hi Nordicnn,
            Apologies for the delay (And thanks again Mdavison for helping out), There is an issue in the plugin i hope to have fixed in the next Beta.
            Also, Given your the first Pump only user ill add the other features (From memory you can tell the RPM and Watt's) i have the Pump only controller, ill try and disconnect my System and install it over the weekend to get it all working for you.
            Mat
              Thanks so much Mat.
              BTW how do I access the beta versions?
                Hi Nordicnn,
                Good news, I have added support (Properly) for the IQ Pump, It took a little longer so you cannot control, or edit Schedules yet, But both are on the way (I have reverse engineered the protocol, just have to code it up...) The Protocol was Different than the Controllers, So a bit painful.
                Anyhow, You should now see some devices available to you, as well as be able to trigger events now.
                To See this you will need to install the Beta version 1.2.0.7
                It is available on the Manage Plugins screen, Towards the bottom in the "Beta" category.
                I will add more support soon, Please let me know if you encounter any issues.
                Mat
                  Hi Mat
                  Thanks so much for the quick update. I installed the beta and new see more devices -- including RPM. I know it's beta but a few (maybe) minor things I noticed:
                  1. The plug-in is listed as version 1.2.0.7 in the beta section, but, when I install it, the version number shows as 1.2.0.6.
ID:	1390120Click image for larger version
                  2. The list of devices showing on the plug-in config page seem to repeat several times. (Actually, it might be repeating indefinitely. I did a count on the page, and it showed 184 repetitions.)
