Hi All,
So lets deal with these 1 by 1, So Serky, I am going to have to debug your system directly, I will contact you Via Private message shortly.
Jono,
I think I know what the issue may be.. In the old API the session would last for days, but sometimes it did stop, so there was a watchdog in place to restart it if that happened, I presume that they may have limited the session length and for some reason the watchdog is not catching it (Perhaps because the connection doesnt actually close, it just stops sending data).
I have mine running in debug to try and catch the issue now.
As a workaround you should be able to restart the plugin and it will work again (For a period at least).
Mat
Jono,
Mat
