BLRfid plugin NOT working in Linux
  • BLRfid plugin NOT working in Linux
    Works fine in Windows Homeseer 3. It does not work in Ubuntu Linux Homeseer 3.
    Testing the plugin in Linux here...validated the serial connection looking at the serial input.
    CS-BTPro:/dev# cat ttyUSB1
    1lW9 1iSz 1lW9 1iSz 1lW9 1iSz 1lW9 1iSz 1lW9 1iSz 1lW9 1lW9 1iSz 1lW9 1iSz ^C
    So when trying to enter /dev/ttyUSB1 in com option box it changes the input to %dev%ttyUSB1.
    Edited the configuration file so it looks like this:
    [Settings]
    supportForumUrl=http://forums.homeseer.com/forumdisplay.php?f=1076
    sendToMessageServerClients=false
    sendToBLBroadcastClients=false
    debugLevel=true
    rfidReceiver1ComPort="/dev/ttyUSB1"
    Not seeing any of the tags though via the logging of the plugin.
    Looks like the plugin is starting fine.
    Jun-28 3:41:35 PM BLRfid start Initializing BLRfid...
    Jun-28 3:41:35 PM BLRfid start BLRfid version is: 2.0.11.0
    Jun-28 3:41:35 PM BLRfid start Loaded configuration successfully
    Jun-28 3:41:35 PM BLRfid start BLRfid Debug Logging is Enabled!
    Jun-28 3:41:35 PM BLRfid start Checking devices owned by BLRfid
    Jun-28 3:41:36 PM BLRfid start No RFID tags or groups have been assigned to BLRfid!
    Jun-28 3:41:37 PM BLRfid start RFID Receiver #1 (/dev/ttyUSB1) is Open!
    Jun-28 3:41:37 PM BLRfid start BLRfid plugin has been initialized
    Jun-28 3:41:37 PM Starting Plug-In Plugin BLRfid started successfully in 2001 milliseconds
    Jun-28 3:41:37 PM Starting Plug-In BLRfid loaded in 3008 milliseconds
    Jun-28 3:41:37 PM Plug-In Finished initializing plug-in BLRfid
    Am I the first to use this plugin in Linux?
    There is nothing seen at all in the debug logs here running the plugin in Linux. Plugin acts fine except that it doesn't see any of the tags.
    Only using 12VDC tags in automobiles and nothing else at this time (well since the beginning of the CheaperRFID plugin in the HS2 days).
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
    You may be the first that has tried it in Linux
    Can you log a ticket on my site for this so I can keep track of it and I will take a look
    Cheers,
    Bob
      Thank you Bob.
      Logged a ticket on your support site.
      Using the RFID device here to test a LoRa 1 watt 8Km transciever (modem)...IE: you can utilize this remotely in out buildings / detached garage for all sorts of stuff and using your plugin to benchmark the device.
      - Pete
      Auto mator
        Yep I saw it - will get to it as soon as I can
        The next 2 weeks at work are gonna be busy as 3 people are off on vacation
        Will let u know
        Cheers,
        Bob
          Not an issue Bob. Thank you for the follow up.
          - Pete
          Auto mator
            You likely need to perform the steps here for the debug logging
            https://forums.homeseer.com/forum/3r...-debug-logging
            Then delete the debug log and capture a new debug
            Strange why you could not log to my site
            Cheers,
            Bob
              I forgot the password and then logged in with the reminder...
              - Pete
              Auto mator
                Thank you Bob for the Linux fix to your BLRFid plugin. Working well on Ubuntu 18.04 64 bit Linux.
                - Pete
                Auto mator
                  You are welcome - glad to help
                  Cheers,
                  Bob
                    Seeing one issue with: (Linux version of plugin)
                    Last Tag Out Of Range shows: Not Set (never changes)
                    Where as in Windows it shows:
                    Last Tag Out Of Range shows: Tag and changes.
                    Should I open a ticket?
                    - Pete
                    Auto mator
                      Yea open a ticket and I will take a look
                      Cheers,
                      Bob
                        Thank you Bob.
                        Well now it looks like it is working. It did not work all week.
                        This morning I disabled the plugin and deleted the Last Tag Out Of Range variable.
                        I then re-enabled the plugin and first auto used I saw a Last Tag Out Of Range with car used.
                        - Pete
                        Auto mator
                          Glad its working
                          Keep an eye on it and let me know
                          Cheers,
                          Bob
